January 10, 2009, 18:44 |
The net is very bad today.. No
#41 |
Vishal Nandigana
Rep Power: 18 |
The net is very bad today.. Not able to upload documents..
I have two vertical blocks connected by a horizontal channel.. The dimensions are as posted above... I created 13 blocks to get the geometry.. So that I have fine mesh near the walls of the vertical block and near the inlet section of the connecting horizontal channel.. I would like to know how to get fine mesh as a symmetry.. simplegrading(2 2 1) would give fine mesh on one side.. I would like to get fine mesh on both the sides and coarse mesh in between.. Kindly give your suggestions.. Thanks Vishal |
[blockMesh] trouble shooting for 3d complex geometry using blockMesh | kush verma | OpenFOAM Meshing & Mesh Conversion | 1 | July 4, 2016 13:29 |
[blockMesh] Trouble using blockMesh for axisymmetric geometry | twinturbotom | OpenFOAM Meshing & Mesh Conversion | 1 | February 8, 2016 21:59 |
[blockMesh] tutorial 2.2 Stress(...) trouble with blockMesh | colinB | OpenFOAM Meshing & Mesh Conversion | 8 | January 22, 2012 11:32 |
Blockmesh cavity error message | tonitoney | OpenFOAM Installation | 2 | March 17, 2008 12:59 |
BlockMesh trouble | r2d2 | OpenFOAM Pre-Processing | 2 | January 16, 2006 10:51 |
