[Commercial meshers] Converting Gambit Neutral Meshes
Old   May 12, 2005, 10:06
Default Converting Gambit Neutral Meshes
Assistant Moderator
Bernhard Gschaider
Hi!
I had to convert some "historical" meshes in the "Gambit Neutral File Format". I've written a converter for those.
I think the general use for that is limited, because if you have Gambit you can write the meshes in the Fluent-Format for which a perfectly good converter already exists. In my case the meshes wre generated by a different program, so I didn't have that option.
Anyway. If there is any need for such a converter, I am happy to share it.
One disclaimer: the meshs I worked with are pure hex meshes. The other cell types (Tet, Pyramids and Wedges) are converted too, they look OK in paraview, but I never did any calculations with them.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   May 12, 2005, 13:13
Default Please forget the previous pos
Assistant Moderator
Bernhard Gschaider
Please forget the previous posting in this thread (forget the whole thread).
Mattijs pointed out to me that this kind of mesh is already converted by the gambitToFoam-utility.
This should teach me to to research more thoroughly before writing something anew and even more thoroughly before posting on the Message Board.
URGENT: need Pointwise Converter to Gambit Neutral File Selissias Main CFD Forum 0 July 20, 2017 09:35
[Salome] IdeasUnvToFoam is very slow when converting meshes armitatz OpenFOAM Meshing & Mesh Conversion 1 May 2, 2017 13:48
Aircraft Sim - TGrid and Gambit Meshes differences Dave S FLUENT 6 March 24, 2008 08:10
how combine two volume MESHES in GAMBIT sreenivas FLUENT 2 October 10, 2007 11:48
set boundary condition in Neutral file, in Gambit Vito Chow FLUENT 2 April 26, 2005 07:50
