[Commercial meshers] Tgrid tetra mehs with problems |
June 17, 2007, 15:16 |
Fabian Braennstroem
Rep Power: 19 |
I have a strange problem with a tetra mesh with prismen and a refinement region for a simple room airflow problem. I get: Exec : fluentMeshToFoam /home/fab/OpenFOAM/fab-1.4/run/tutorials/simpleFoam Nottage_06_2007 Nottage_OB_ANSA_normaler_Durchmesser_Tetra_Refinem ent_Prismen_1_2.msh Date : Jun 17 2007 Time : 20:07:12 Host : node1.ddorf.de PID : 6347 Root : /home/fab/OpenFOAM/fab-1.4/run/tutorials/simpleFoam Case : Nottage_06_2007 Nprocs : 1 Create time Reading header: "TGrid 3D 4.1.3" Found unknown block4 Embedded blocks in comment or unknown: ( Found end of section in unknown Found end of section in unknown Dimension of grid: 3 Number of points: 300035 number of faces: 2684605 Number of cells: 1273424 Found unknown block3010 Embedded blocks in comment or unknown: ( Found end of section in unknown Embedded blocks in comment or unknown: ( @Embedded blocks in comment or unknown:� Embedded blocks in comment or unknown:�� @33Embedded blocks in comment or unknown:@� �]�@�Embedded blocks in comment or unknown:�� �ound end of section in unknown:? �`@@�@33@Embedded blocks in comment or unknown:4� Found end of section in unknown:� Does anyone have an idea, what I can do? The mesh was written binary. Regards! Fabian |
June 17, 2007, 15:32 |
Sorry, where is the error - I
Hrvoje Jasak
Rep Power: 33 |
Sorry, where is the error - I cannot see it. In any case, you will need to write the mesh ascii for the converter fo work.
There are known problems with the consistency of Fluent mesh and case files, which get cleaned up quietly when they go through Fluent. What makes it more difficult is that I didn't use Scheme to read the file when I wrote the converter in the first place.
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
June 18, 2007, 04:39 |
Hi Hrvoje,
I thought, the e
Fabian Braennstroem
Rep Power: 19 |
Hi Hrvoje,
I thought, the error is: �]�@�Embedded blocks in comment or unknown:�� �ound end of section in unknown:? �`@@�@33@Embedded blocks in comment or unknown:4� Found end of section in unknown:� I will use an ascii mesh, thanks! Regards! Fabian |
Benchmark Problems to test a new scheme for Convection-diffusion equation | alibaig1991 | Main CFD Forum | 1 | June 16, 2018 05:30 |
Needed Benchmark Problems for FSI | Mechstud | Main CFD Forum | 4 | July 26, 2011 13:13 |
[TGrid] Tgrid hybrid mesh pyramid transition | tony00 | ANSYS Meshing & Geometry | 4 | November 26, 2009 05:36 |
HELP! TETRA and HEXA boundary | sunlight007 | Siemens | 6 | August 6, 2004 07:15 |
Some problems with Star CD | Micha | Siemens | 0 | August 6, 2003 14:55 |
