[Commercial meshers] Ascii Fluent msh OF Fatal IO Error regIOobjectReadC at line 66
Old   August 9, 2007, 07:22
Default Ascii Fluent msh OF Fatal IO Error regIOobjectReadC at line 66
David Sponiar
sponiar is on a distinguished road
Hello everybody,
system: Suse 10.0, x86_64, opteron.
installation: successfull
foamInstallationTest: no critical error, no warnings.
When I try to convert tutorial fluent mesh file (.../tutorials/icoFoam/elbow/), I've got this message:
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4.1 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : fluentMeshToFoam r c elbow.msh
Date : Aug 09 2007
Time : 12:07:03
Host : opteron1
PID : 9818
Root : r
Case : c
Nprocs : 1
Create time
--> FOAM FATAL IO ERROR : cannot open file
file: r/c/system/controlDict at line 0.
From function regIOobject::readStream(const word&)
in file db/regIOobject/regIOobjectRead.C at line 66.
FOAM exiting
Same error message get, when I try to convert simple mesh file from gambit and Tgrid. Mesh file does not contain any MRF, interface/internal BC, periodicy atc.
Thanks a lot for your response
sponiar is offline   Reply With Quote
Old   August 9, 2007, 07:27
Default And where is the case director
Hrvoje Jasak
And where is the case directory that you are trying to make the mesh for? From the directory where you are trying to run, do:
ls l r/c/system/controlDict
and take it from there.
Hrv
Hrvoje Jasak
Old   August 9, 2007, 08:19
Default Thank you for fast response. T
David Sponiar
Thank you for fast response. Truth is, I didn't understand quite well to marking place <root> <case>. Well. I am just in tutorial directors tree:
.../tutorials/icoFoam>
Type to shell:
fluentMeshToFoam ./ elbow elbow.msh
And get this message:
--> FOAM FATAL ERROR : fluentMeshToFoam: file "elbow.msh" not found
From function fluentToFoam::main(int argc, char *argv[])
in file fluentMeshToFoam.L at line 894.
FOAM exiting
It is still looking like my understanding to <root> and <case> is not quite bright. Could you tell me, what should I type after fluentMeshToFoam?
<root> ./ ... place, when I am just now
<case> ... director, which content mesh file
and finally filename of mesh file. Is it correct?
Sponiar D.
Old   August 9, 2007, 08:51
Default After all, I break it. I find
David Sponiar
I find correct syntax for converting mesh file.
fluentMeshToFoam . msh_dir msh_dir/mesh_file.msh
Eureka!
It is my first step with OpenFOAM, so I am deeply sorry for primitive questions.
Thanks for patience.
David S.
Old   December 12, 2008, 19:42
Default Hi David! I have the same p
mayol
roger is on a distinguished road
Hi David!
I have the same problems as you had, but I don't know what to write after fluentMeshToFoam. My new case is in simpleFoam (it is called Malla), and my .msh file is called MALLA.msh. Sorry, I'm quite new in it. Thanks in advanced
roger is offline   Reply With Quote
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
[OpenFOAM] could not open file .vtk in paraview ali_atrian ParaView 8 August 27, 2014 11:31
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 22:45
