[Commercial meshers] Problem in running mesh imported from fluent to foam
Old   October 30, 2008, 00:45
Default Problem in running mesh imported from fluent to foam
Vishal Jambhekar
vishal is on a distinguished road
I have imported a mesh from Fluent to OpenFoam mesh is converted sucessfully but after i apply boundry conditions and run it i am getting following error even if the Courant Number is very small
Can anyone help me in this matter:
Time = 2.53e-06
Courant Number mean: 0.00019371 max: 0.0119133
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Ux, Initial residual = 0.000946563, Final residual = 1.76591e-10, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.00203507, Final residual = 2.71693e-10, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.000729181, Final residual = 2.00435e-10, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 0.000308165, Final residual = 5.5886e-10, No Iterations 1
Maximum number of iterations exceeded#0 Foam::error::printStack(Foam:stream&) in "/home/user/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/user/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::hThermo<foam::puremixture<foam::consttranspo rt<foam::speciethermo<foam::hc onstthermo<foam::perfectgas> > > > >::calculate() in "/home/user/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libbasicThermophysicalMode ls.so"
#3 Foam::hThermo<foam::puremixture<foam::consttranspo rt<foam::speciethermo<foam::hc onstthermo<foam::perfectgas> > > > >::correct() in "/home/user/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libbasicThermophysicalMode ls.so"
#4 main in "/home/user/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/sonicTurbFoam "
#5 __libc_start_main in "/lib64/libc.so.6"
#6 Foam::regIOobject::readIfModified() in "/home/user/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/sonicTurbFoam "
From function specieThermo<thermo>::T(scalar f, scalar T0, scalar (specieThermo<thermo>::*F)(const scalar) const, scalar (specieThermo<thermo>::*dFdT)(const scalar) const) const
in file /home/dm2/henry/OpenFOAM/OpenFOAM-dev/src/thermophysicalModels/specie/lnInclude/ specieThermoI.H at line 78.
FOAM aborting
Aborted
user@zeus10:~/OpenFOAM/Vishal/run/Fluent/Mesh_Fluent>
Cheers,
Vishal Jambhekar...
"Simulate the way ahead......!!!"
vishal is offline   Reply With Quote
Old   February 4, 2009, 04:15
Default Hi Vishal Jambhekar This
venkateshtl
Hi Vishal Jambhekar
This is Venkatesh here i created NACA0012 airfoil in Gambit exportted into fluent .Now i need to convert FluentToFoam convversion.But i am not getting it so can u please suggest the way to convvert fluent file into Foam format to compare the result of fluent and openGoam
Old   February 6, 2009, 11:05
Default Have you scaled your mesh whil
Rishi .
hellorishi is on a distinguished road
Have you scaled your mesh while importing it from fluent?
check wiki on how to scale:
http://openfoamwiki.net/index.php/Fluent3DMeshToFoam
Courant number is dependent on dt and dx. So my guess is tweaking one of them will bring the courant number to desired level.
dx can be tweaked while importing the mesh
fluent3DMeshtoFoam fluent.msh -scale 0.001
dt can be tweaked in system/controlDict file deltaT
hellorishi is offline   Reply With Quote
Problem concerning FLUENT dynamic mesh fabian.g FLUENT 0 August 28, 2017 12:56
Fluent mesh problem mariashva FLUENT 1 August 15, 2017 04:17
Problem in running coarse mesh(on the other hand fine mesh is running) ashokmoravaneni OpenFOAM 7 July 17, 2017 05:56
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
