February 11, 2004, 11:14 |
List of Error codes
Is there a list of error codes and their meaning?
For instance, When I tryied to convert from gambit to foam, I got error code 6, but I dont know what it is. Thanks, Luiz |
February 11, 2004, 11:56 |
Foam does not print error cod
Foam does not print error codes, only error messages so I imagine your message comes from somewhere in the operating system.
Is it a 'bus error' (signal 6)? Do you get any other messages? Do you get a core file? Does it show anything in the debugger? You have full sources for gambitToFoam in $FOAM_UTILILTIES/mesh/conversion, if you add -g -O0 -DFULLDEBUG \ to Make/options and recompile ('wmake') and run in the debugger does it show something interesting? |
February 11, 2004, 12:05 |
If the mesh file from gambit
If the mesh file from gambit is binary format you might expect the problem you describe. Try ascii.
February 11, 2004, 12:16 |
I got error code 6 in the jav
I got error code 6 in the java environment of FoamX.
Apparently my Gambit case was not correctly set. (it was missing boundary conditions at surfaces). Thank you very much, Luiz |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 10:07 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 04:04 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
