[Other] Ansys meshes
Old   November 22, 2005, 11:52
Default Ansys meshes
azt
Hi
Is it possible to read in ansys meshes easily?
thanks
allan
Old   November 22, 2005, 23:00
Default Currently, there is no Ansys c
Hrvoje Jasak
Currently, there is no Ansys converter because I could not get hold of the detailed mesh file format information. Also, if I remember correctly, there were some issues with defining boundary patches. However, writing a new one is pretty easy, based on the existing converters and mesh-from-cell-shapes stuff in polyMesh.
Overall, I would say it's about a day's work. Do you have all the info and how badly do you need this? Is there an option of going through some of the other mesh formats that are already supported?
Hrv
Hrvoje Jasak
Old   November 23, 2005, 04:14
Default Hrvoje I can probably read
azt
Hrvoje
I can probably read the ansys mesh into star-cd and then use the utility starToFoam. It's just a bit of a problem as that ansys and star-cd are not really on the same site, and a bit of walking is required.
Thanks
allan
Old   November 23, 2005, 10:54
Default I am quite prepared to write a
Hrvoje Jasak
I am quite prepared to write a converter but:
- I need all the data
- it won't be done immediately
- somebody needs to test it or give me examples + check them later because I haven't got any Ansys meshes
If you need it urgently, then the game is different :-)
Have fun,
Hrv
Hrvoje Jasak
Old   November 23, 2005, 11:21
Default Hrv That would be great!
azt
Hrv
Tell me what you need? I can provide simple grids to quite complex ones.
allan
Old   November 23, 2005, 19:39
Default Hi, Here is a good link for
jvw245
Here is a good link for documentation of the ANSYS cards.
http://www.cesup.ufrgs.br/ansys/prog_55/g-int/INS3.htm
For files generated from ANSYS with the command cdwrite you should clarify whether Blocked or Unblocked format is used.
Joe
GPU acceleration in Ansys Fluent flotus1 Hardware 63 May 12, 2023 03:48
[ANSYS Meshing] Connection of two meshes in ANSYS meshing adele ANSYS Meshing & Geometry 8 March 27, 2018 07:54
[ANSYS Meshing] Can start ANSYS meshing only one time on ubuntu 16.04 Touré ANSYS Meshing & Geometry 2 September 26, 2017 06:41
Ansys workbench problem Jonny6001 ANSYS 2 September 30, 2010 13:59
Hexa Block meshes in ANSYS Meshing? siw ANSYS Meshing & Geometry 3 July 31, 2009 11:40
