[Other] Meshing tool for FV with Foam
Old   December 5, 2005, 13:34
Default Meshing tool for FV with Foam
frederic.deghetto@free.fr
frederic is on a distinguished road
Which meshing tool do you recommend me for using openfoam ?
Thanks you,
Frederic
frederic is offline   Reply With Quote
Old   December 6, 2005, 04:32
Default Hello Fredric OpenFOAM has it
Lars Edvarsen
edvardsenpriv is on a distinguished road
Hello Fredric
OpenFOAM has its own simple mesh generator, blockMesh, and a range of utilities of mesh manipulation, see:
http://www.opencfd.co.uk/openfoam/in...meshGeneration and
http://www.opencfd.co.uk/openfoam/in...shManipulation
If you however find blockMesh a bit too timeconsuming to use (as myself), there are quite a few mesh converters included in OpenFoam, see:
http://www.opencfd.co.uk/openfoam/in...meshConversion
There is one converter missing on the list: netgenNeutralToFoam
It is my impression that for those who don't have access to ay commercial mesher, Netgen(http://www.hpfem.jku.at/netgen/index.../download.html), tetgen(http://tetgen.berlios.de/) or Gmsh(http://www.geuz.org/gmsh/) is most used. Personally I only have experience with Netgen. The good thing about Netgen is that you can import *.step files from 3D CAD programs.
Lars
edvardsenpriv is offline   Reply With Quote
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
[mesh manipulation] refineMesh Error mohsen.boojari OpenFOAM Meshing & Mesh Conversion 3 March 1, 2018 23:07
[Gmsh] 3D coil mesh: can't create the volume? RomainBou OpenFOAM Meshing & Mesh Conversion 3 July 18, 2016 06:09
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
Derivative of velocity and mean velocity hiuluom OpenFOAM Post-Processing 1 May 30, 2015 00:42
