[Commercial meshers] FluentMeshtoFoam with internal solid surface |
May 29, 2007, 07:12 |
hello all,
I tried to convert a Icemcfd mesh by first exporting to fluent mesh then using fluentmeshtofoam utility. The original mesh consisted of outer wall with an internal solid wall.However when converting the mesh only the outer surface mesh remained. I have read the documentation and it does not allow such types of conversion. So can anyone tell alternatives for successful conversion of internal solid wall also. Thanks. Mayank |
May 29, 2007, 07:37 |
Hi Mayank,
Yes, you can split
Dragos
Rep Power: 20 |
Hi Mayank,
Yes, you can split the mesh and have two volumes. Check the forum and the wiki for examples on how to do that.... or ask for more help. Dragos |
May 29, 2007, 09:20 |
Hello Dragos,
The geometry
Hello Dragos,
The geometry consists of outer cuboidal wall and internal sprinkler with a cone head.It is a part of bigger reactor.When I converted only outer cuboidal was visible. I am a beginner in openfoam and would appreciate further help regarding split mesh and any other alternatives. Mayank. |
May 30, 2007, 03:57 |
Hi Mayank,
I hope this tutori
Dragos
Rep Power: 20 |
Hi Mayank,
I hope this tutorial will be helpful for you: Internal walls For future topics that you might be interested in, try the "Search" utility on this forum or on the wiki page above, it will be much faster than waiting for an answer. Dragos |
Strange behavior of water surface near solid body | JBrake | OpenFOAM Running, Solving & CFD | 6 | January 16, 2019 18:51 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 12:05 |
[snappyHexMesh] SnappyHexMesh Internal Flow Example (Diesel Injector) | Irish09 | OpenFOAM Meshing & Mesh Conversion | 23 | July 15, 2013 08:45 |
Heat Flux at Internal walls or Fluid Solid Interface | Mahi | CFX | 3 | October 1, 2012 03:18 |
ICEM CFD 5.0 (Hexa) - Internal Wall/Thin Surface | James Date | CFX | 3 | August 10, 2012 05:47 |
