[Salome] Salome
Old   August 30, 2008, 06:47
Default Salome
stefano zinna
giordy is on a distinguished road
Does someone know how to use SALOME to manage multiphysiscs?
If i well understood Openfoam connect different meshed regions but the connectd face between two regions should have the same boundary nodes. Is is correct?
If yes, how SALOME can create two meshed objects with the same boundary nodes in one face?
Thanks in advance for any reply.
Stefano
giordy is offline   Reply With Quote
Old   August 30, 2008, 08:02
Default Hi Stefano, I think you can
Marco Moscaritolo
mavimo is on a distinguished road
Hi Stefano,
I think you can create mesh into Salomé and using funkySetFields to add different phase into mesh, or create two different regions into Salome and generate mesh for your obj; after mesh creation export cell_gamma value and convert it into OF format (using sed || awk).
Bye
Marco
mavimo is offline   Reply With Quote
Old   September 2, 2008, 13:49
Default Hi Marco. Many thanks for y
stefano zinna
Hi Marco.
Many thanks for your fast reply.
I started to use OpenFoam from few weeks and i would like to have a CAD sofwtare to deal with complex geometris. Salomè can import Iges and Step and has many utilities to work on geometry and mesh it. So it is what i need. FunkySetFields can add different phase into mesh but it is hard to use with complex geometries. Isn't ?
About the second possibility that you mention: if i am not wrong OpenFOAM manage multyphisics only if the connected surface has the same node numbers and positions for the two geometries. Hence when i generate two different meshes with Salome i have to assure that.
Let me know your opinion because i am new user both for OpenFoam and Salome and maybe i can be wrong.
Stefano
Old   September 5, 2008, 08:36
Default 1) yes, but for complex geomet
Marco Moscaritolo
1) yes, but for complex geometry funkySetField is not very easy to use, but I think is possible, for example, if your model is a U tube and your idea is set gamma = 1 into bottom of tube, you can create a region that include bottom of tube (U region), not require have a function to describe U region. If your geometry is very complex you can use funkySetField more then unoe time to sett gamma for every mesh element.
2) yes, you must build a mesh with Salomé where every point of interface is the same (for mesh 1 and mesh 2), and after remove duplicate vert. Isn't very easy to do, but also not impossible.
Bye
Marco
PS: if you can write italian plz contact me by mail.
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 07:01
Salome cgns format mesh to SU2 JPBLourenco SU2 19 November 18, 2019 03:11
[Salome] SALOME : How to define several CellZone utawalpa OpenFOAM Meshing & Mesh Conversion 0 March 23, 2018 14:19
Salome and Code Saturne simulation of simple room and objects cristian.ocnarescu Main CFD Forum 0 June 21, 2010 11:19
salome, openfoam and moving mesh prhlava OpenFOAM Running, Solving & CFD 8 November 9, 2009 09:59
