[Commercial meshers] GridPro to OpenFOAM converter
Old   September 9, 2010, 10:17
Bryan Lewis
lewisb2 is on a distinguished road
Vinc,
I am just starting with gidPro, trying to mesh turbine runners. What do you do to get your surface geometry into gridPro? I have tried the iges2gp and get errors. I have also tried converting patran and nastran surface meshes, but that just gives me a mesh, and I do not know how to fix surface topology to it.
-Bryan
lewisb2 is offline   Reply With Quote
Old   September 9, 2010, 10:50
Vincent RIVOLA
vinz is on a distinguished road
Hi Bryan,
You should use stl files to import into GridPro.
But we should keep this topic for the converter. I will be pleased to reply to your GridPro related questions by email (vincent.rivola@rtech-engineering.com) or by PM as you want.
Regards,
Vincent
vinz is offline   Reply With Quote
Old   December 16, 2010, 03:55
pad
PA
pad is on a distinguished road
Hi there,
I am trying to use the options in gridpro2foam to create facesets for runtime data extraction.
However, for this to work I hoped that the face numbering would be identical when gridpro2foam is used with or without the --solid option. When having more than one 2-sided surface in gridpro it doesn't seem to work.
This is the face numbering when not using the --solid option
4
Volute
type Volute;
nFaces 8250;
startFace 315159;
Inflow
type Inflow;
nFaces 2880;
startFace 323409;
Pipe
type Pipe;
nFaces 2592;
startFace 326289;
Outflow
type Outflow;
nFaces 504;
startFace 328881;
and this is when using --solid 3
(BC 3 and 5 are 2-sided surfaces in gridpro)
6
Volute
type Volute;
nFaces 8250;
startFace 314655;
Inflow
type Inflow;
nFaces 2880;
startFace 322905;
Flange
type Flange;
nFaces 504;
startFace 325785;
Pipe
type Pipe;
nFaces 2592;
startFace 326289;
Outflow
type Outflow;
nFaces 504;
startFace 328881;
Flange-bis
type Flange-bis;
nFaces 504;
startFace 329385;
Can someone explain to me why the face numbering is not identical for at least the first two patches?
Furthermore, I get the following output:
Not processing BC -1
Processing BC 1
Processing BC 2
Processing BC 3
Processing BC 4
Processing BC 5
Processing BC 6
Processing BC 5003
The last BC seems a bit odd to me as the connectivity file only includes 6 BCs numbered from 1-6.
Regards,
Per
pad is offline   Reply With Quote
Old   July 19, 2011, 04:54
Default download gridpro2foam converter
  #24
Stefan
SD@TUB is on a distinguished road
Hello FOAMers,
the download link provided by R.Tech
Originally Posted by vinz View Post
Dear OpenFoamers,
Here comes a new version of GridPro2FOAM.
The software can be downloaded at the following page:
http://www.rtech-engineering.com/news.html
is off. Does anybody know, which is the current version of gridpro2foam and where to download it?
/Stefan
SD@TUB is offline   Reply With Quote
Old   July 19, 2011, 04:56
Vincent RIVOLA
Dear Stefan,
The last version of GridPro2Foam is 5.12.
I am going to upload it to our server and will put the link here in a moment.
Old   July 19, 2011, 06:07
Vincent RIVOLA
Here it is:
http://www.rtech-engineering.com/Ope...2FOAM_5.12.zip
Do not hesitate to contact us if you have a problem or a recommendation on the converter.
Old   February 5, 2015, 03:50
Default Problems converting mesh with periodic boundaries
  #27
pad
PA
I have some trouble doing a proper conversion of a very simple periodic mesh. The problem is that one of the periodic boundaries is moved during the conversion.
Looking through the code it seems that the periodic angle is hardcoded - is this intentional? If I change the period in Gridpro to match the hardcoded angle the mesh looks fine but I rarely have a period matching this :-)
double periodicAngle = 360/11.;
double theta =  -(atan2(n1->z,n1->y)>atan2(n2->z,n2->y)?-periodicAngle*M_PI/180.:periodicAngle*M_PI/180.);
I am using gridpro2FOAM v5.12.
Regards,
Per
Getting Started with OpenFOAM wyldckat OpenFOAM 26 June 21, 2024 07:54
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 09:51
OpenFOAM Training: Programming CFD Course 12-13 and 19-20 April 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 14, 2016 11:19
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
OpenFOAM Training and Workshop Zagreb 2628Jan2006 hjasak OpenFOAM 1 February 2, 2006 22:07
