[Other] Best mesh generation software for OpenFOAM
Like Tree8Likes
Old   November 21, 2016, 08:28
NablaDyn's Avatar
NablaDyn is on a distinguished road
For MegaCads meshes in OpenFOAM see:
http://www.cfd-online.com/Forums/ope...tml#post626231
NablaDyn is offline   Reply With Quote
Old   December 4, 2016, 22:37
Vu
DoQuocVu is on a distinguished road
For me, since I've just tried GMSH, SnappyMesh, SALOME and from my limited experience, I can handle every kind of Mesh using either GMSH or SnappyMesh.
GMSH is used for a not very complicated models and it offers many functions for controlling the Mesh
SnappyMesh is used for more complicated models (but it is not really good for models which have high aspect ratio features). All i have to do is creating a .stl file by any CAD software.
highhopes and OpenFOAM2016 like this.
DoQuocVu is offline   Reply With Quote
Old   December 5, 2016, 03:56
Emre
ordinary is on a distinguished road
ANSYS Meshing is really good. I think its GUI is unchallengeable.
ordinary is offline   Reply With Quote
Old   February 15, 2017, 19:43
Mike
OpenFOAM2016 is on a distinguished road
I am new to OpenFOAM. What do mean by complicated models?
OpenFOAM2016 is offline   Reply With Quote
Old   April 21, 2017, 07:17
KaLium's Avatar
Kal-El
KaLium is on a distinguished road
blockMesh + SnappyHexMesh. (Solidworks for creating the geometry)
KaLium is offline   Reply With Quote
Old   May 30, 2017, 08:31
LeeRuns is on a distinguished road
Originally Posted by philippose View Post
My vote goes without any second thoughts to the one and only.... Netgen v4.5 :-)!
The software seriously rocks when it comes to mesh generation! I have been using it for over a year now, and always keep it up to date from CVS....
So far... the only complaint I have is that it does not do a good job when there are long narrow gaps (for example concentric cylinders with gaps which are very small compared to the rest of the geometry).
Also... it can only create pure tetrahedral meshes in 3D (though, for my applications... this does not seem to be so much of a limitation)
As for importing into OpenFOAM... flawless.... Mesh Quality... very very acceptable.... Complexity.... hardly complex :-)..... Type of geometries it can handle... yet to find one which it cannot handle :-)!
It can directly import STEP and IGES files (if compiled with OpenCascade support)... and I dont need to do anything special when exporting out of Pro/E.
And on a purely personal note.... I have tried Gmsh and Tetgen... but found netgen to be much more user friendly... and the GUI easier to work with.
Philippose
Which one is best for the small thin regions like the one you described above?
Originally Posted by gdbaldw View Post
I too needed hex, not tet. blockMesh does hex, but is difficult for anything but simple geometry. I assure you that Blender is a very capable tool for generating a surface mesh made of quads, and that Calculix can extrude this surface using the Python script I posted in another thread.
Furthermore, I have a technique now for generating "manifolds" from the Blender surface mesh, and using Calculix to create "columns" of hex between each manifold. To generate manifolds I first use a seperate Python script to project normals from the quad surface and make any manual adjustments needed, then export to Calculix. Exports from Calculix to OpenFOAM are without error.
If you'd like to learn this technique, I'd be happy to share my experience with you through this forum, so that others may also benefit. A formal tutorial is really needed, but for now some of my prior postings may be useful as an introduction to this technique.
Doug
Sent from my SM-G930V using CFD Online Forum mobile app
LeeRuns is offline   Reply With Quote
Old   May 30, 2017, 11:19
Ash Kotwal
Ash Kot is on a distinguished road
BETA CAE systems, ANSA pre-processor.
All above solutions, they consume high amount of Memory and processing power of CPU for large model support. This one can perform computation on lower specifications of systems.
Sent from my iPhone using CFD Online Forum mobile app
Ash Kot is offline   Reply With Quote
Old   August 2, 2023, 17:11
Default Mesh Generation for OpenFOAM
  #28
Michael E. Hohmeyer
hohmeyer is on a distinguished road
Ennova is a commercial pre- post- processor that can import, clean and repair CAD and generate tet + prism meshes or polyhedral meshes with boundary layers. It has a full GUI for setting up the openFOAM dictionaries and has post processing. Free for students ! Reasonable cost for commercial applications. Visit www.ennova-cfd.com. Thanks -Mike
File Type: jpg Screenshot 2023-08-02 at 1.10.07 PM.jpg (125.5 KB, 13 views)
cfdberkeley likes this.
hohmeyer is offline   Reply With Quote
Old   August 3, 2023, 15:15
Ash Kotwal
Hi Mike,
I reached out to ennova-cfd via email 'info@ennova.tech' to request a student license for meshing software. I have not received any response them yet.
Would really like to use the meshing software which can generate better meshes for complex geometries such as burners and combustors.
And since I being in university as student, I would like to avail the opportunity of using the software created by the original creator of ICEM CFD software for 'less cost' to 'no cost' options.
Old   August 3, 2023, 20:00
Default Ennova CFD for OpenFOAM
  #30
Michael E. Hohmeyer
File Type: jpg Screenshot 2023-08-02 at 1.10.07 PM.jpg (125.5 KB, 5 views)
Old   August 14, 2023, 18:48
Default Ennova
  #31
Michael E. Hohmeyer
Ennova is a commercial pre- post- processor that can import, clean and repair CAD and generate tet + prism meshes or polyhedral meshes with boundary layers. Also has a GUI for setting up OpenFOAM dictionaries. Free for students ! Reasonable cost for commercial applications. Visit www.ennova-cfd.com. Thanks -Mike
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
[ANSYS Meshing] Question about mesh generation learning lnk ANSYS Meshing & Geometry 2 July 7, 2012 07:45
Recommendation for mesh generation software tibich72 Main CFD Forum 8 June 9, 2011 12:24
Mesh generation software is needed H.Dou Main CFD Forum 12 May 4, 2011 16:20
