September 13, 2005, 08:17 |
ScalePoints
Håkan Nilsson
Rep Power: 18 |
I need to scale a mesh from [mm] to [m], and the UserGuide tells me to use scalePoints. I can't however find scalePoints in OpenFoam 1.2.
How do I perform this operation in OpenFoam 1.2? Håkan. |
September 13, 2005, 10:00 |
I think in 1.2, this has been
Pei-Ying Hsieh
Rep Power: 18 |
I think in 1.2, this has been changed to
transformPoints. You can do this from either the command line or within FoamX |
September 13, 2005, 10:06 |
Thanks, I just found it myself
Håkan Nilsson
Rep Power: 18 |
Thanks, I just found it myself, and I guess that the following does the job:
transformPoints <root> <case> -scale "(1e-3 1e-3 1e-3)" Please update the manual as soon as you have the time. Håkan. |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
[mesh manipulation] ScalePoints tool | cedric_duprat | OpenFOAM Meshing & Mesh Conversion | 6 | September 19, 2008 04:15 |
