[mesh manipulation] AutoRefineMesh
Old   April 29, 2007, 10:37
Default AutoRefineMesh
BastiL
bastil is on a distinguished road
so far I did not use to much of the meshing Tools from Foam, only solvers. Now I found autoRefineMEsh after looking around a bit today.
I think it is very interestign. I used blockmesh to generate a course bounding box hexa mesh and did autoRefinement afterwards. But I am not sure what it exactly did. CheckMesh gives me Hexas and Polys afterwards, but Paraview shows more or less Tetrahedrals. Is there som example or additional documentation about it?
Basti
bastil is offline   Reply With Quote
Old   April 30, 2007, 10:28
Default ParaView cannot display polys
Eugene de Villiers
eugene is on a distinguished road
ParaView cannot display polys properly, so decomposes them into tetras for display purposes.
eugene is offline   Reply With Quote
Old   April 30, 2007, 16:47
Default I expected that. I saw OpenDX
BastiL
I expected that. I saw OpenDX is able to display the mesh properly?
What I am wondering: Is the mesh body fitted? Or is body-fitting possible with some of the Options which I dont understand?
Old   April 30, 2007, 18:31
Default If you look at the patches (v.
Mattijs Janssens
mattijs is on a distinguished road
If you look at the patches (v.s. the internal mesh) you'll see the outside polyhedra correctly.
OpenDX has the same problem (and uses a similar decomposition) but can display the edges of the mesh correctly
The mesh is not body fitted and there is no option to do so.
mattijs is offline   Reply With Quote
Old   May 1, 2007, 08:00
Default Thanks for this, Mattijs. How
BastiL
Thanks for this, Mattijs. How can I look a the patches in paraview?
So what are the following options good for:
With them I dont see a difference, I always get three cell sets:
selectCut
selectInside
selectOutside
I thought this was for body fitting but whats it good for?
geometricCut false;
UseHexTopology yes;
Thanks Basti
Old   May 1, 2007, 09:24
Default use foamToVTK, it writes separ
Markus Hartinger
hartinger is on a distinguished road
use foamToVTK, it writes separate files for each patch. use paraview to see the vtk-files
hartinger is offline   Reply With Quote
Old   May 1, 2007, 17:14
Default The cellSets are to select par
Mattijs Janssens
The cellSets are to select part of the mesh. Use subsetMesh.
The default refinement method is to cut with a plane through the cell centre (geometricCut=true). For pure hexes (i.e. cells with 8 vertices and 6 quad faces) it can do a topological cut (UseHexTopology=true) since for hexes the concept of a direction actually makes sense.
[Other] AutoRefineMesh Friendly OpenFOAM Meshing & Mesh Conversion 0 October 17, 2017 16:03
[Other] autoRefineMesh mikeP OpenFOAM Meshing & Mesh Conversion 0 March 7, 2013 07:06
[CAD formats] Recommended way of generating mesh from cad Tobias Prousa (Prousa) OpenFOAM Meshing & Mesh Conversion 24 March 19, 2009 20:31
Incorrect labelList initialization in autoRefineMesh 7islands OpenFOAM Bugs 1 August 8, 2008 04:48
[mesh manipulation] AutoRefineMesh utility pbo OpenFOAM Meshing & Mesh Conversion 8 March 18, 2007 02:08
