[mesh manipulation] RotateMesh Dictionary File
Old   March 5, 2008, 12:57
Default RotateMesh Dictionary File
Antonio Martins
titio is on a distinguished road
Send a message via MSN to titio Send a message via Skype™ to titio
Does anybody know where openFoam saves the dictionary file used by the mesh utility rotateMesh. In the FoamX menu the name of a dictionary file appears, but, i cannot find it.
Thanks,
António
titio is offline   Reply With Quote
Old   March 6, 2008, 05:57
Default RotateMesh does not read a dic
Mattijs Janssens
mattijs is on a distinguished road
RotateMesh does not read a dictionary. The FoamX configuration was probably never adapted.
rotateMesh <root> <case> '(1 0 0)' '(0 1 0)'
rotates mesh and (vector/tensor) fields 90 degrees around z axis (from x-axis to y-axis).
mattijs is offline   Reply With Quote
Old   March 12, 2008, 11:15
Default Hi, I think you are asking
Gabriela Bracho
gaby is on a distinguished road
I think you are asking for the utility location. You can find the rotateMesh.C in
~/OpenFOAM/OpenFOAM-1.4/applications/utilities/mesh/manipulation/rotateMesh
Have a Nice day.
Gaby
gaby is offline   Reply With Quote
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
