[mesh manipulation] RefineMesh tetrahedral
Old   April 18, 2008, 15:35
Default RefineMesh tetrahedral
Mark Couwenberg
markc is on a distinguished road
Dear Foamers,
Has anyone succeeded in using refineMesh on a tetrahedral mesh? I want to use this utility in order to use surface capturing refinement. I want to model free surface waves caused by ships. It seems very hard to create a mesh with hex when curved ships hulls are involved.
However, if I am right, refineMesh only works on hex meshes. At least I just tried it on my tet mesh but checkmesh gave a lot of errors.
Is there any possibilty to model the water-air interface by some kind of moving/sliding interface?
Any help will be greatly appreciated.
Mark
markc is offline   Reply With Quote
Old   April 18, 2008, 17:05
Default Mathematically it does not see
Mark Couwenberg
Mathematically it does not seem very demanding to me. Add a point in the middle of a tet, add edges from this new point to old corner points etc. Or am I overlooking something?
However, I have no idea how to code this properly in C.
Mark
Old   August 26, 2010, 01:49
Default refineMesh tetrahedral
Hrushikesh Khadamkar
Hrushi is on a distinguished road
I am also trying to use refineMesh on tetrahedral mesh. Have you succeded in doing that? If yes, can u give some hints?
Hrushikesh
Hrushi is offline   Reply With Quote
Old   December 7, 2010, 10:16
Marc-Florian Uth
Marc10 is on a distinguished road
Is mesh refinement of tetrahedral cells implemented in the new version 1.7.1?
Marc10 is offline   Reply With Quote
[mesh manipulation] Unstructured tetrahedral mesh Refinement using REFINEMESH DICT UTILITY.???? POSSIBLE? saddy OpenFOAM Meshing & Mesh Conversion 4 February 1, 2019 06:58
[mesh manipulation] multiple calls to refineMesh parallel w/ dict failing Regis_ OpenFOAM Meshing & Mesh Conversion 2 June 4, 2015 14:44
[mesh manipulation] checkMesh Erros after refineMesh mgdenno OpenFOAM Meshing & Mesh Conversion 10 October 14, 2014 06:16
[mesh manipulation] Cannot get refineMesh to run in parallel smschnob OpenFOAM Meshing & Mesh Conversion 2 June 3, 2014 12:20
tetrahedral refinement with refineMesh help please!!!! mrshb4 OpenFOAM 0 December 11, 2010 15:07
