[snappyHexMesh] SnappyHexMesh internal walls
Old   July 23, 2008, 20:33
Default SnappyHexMesh internal walls
Pierre-Olivier Dallaire
podallaire is on a distinguished road
I was wondering if it would be possible to create internal walls (zero-thickness) using snappyHexMesh based on the stl file. The idea would be to apply "createBaffles" on a faceZone defined by snappyHexMesh.
Does it sound possible ?
Best regards,
Pierre-Olivier
podallaire is offline   Reply With Quote
Old   July 24, 2008, 10:09
Default You don't need to apply create
Eugene de Villiers
eugene is on a distinguished road
You don't need to apply create baffles or do anything special, just insert a surface where you want the zero thickness wall. A cutting surface doesn't need to be watertight.
eugene is offline   Reply With Quote
Old   July 24, 2008, 10:12
Default Eugene, thanks - I'll give
Eugene,
thanks - I'll give it a try today.
Regards,
Pierre-Olivier
[ANSYS Meshing] How to create Internal walls using Ansys meshing? shivasluzz ANSYS Meshing & Geometry 1 November 19, 2018 10:16
[snappyHexMesh] snappyHexMesh and blockMesh for internal flow (leaking geometry?) vaina74 OpenFOAM Meshing & Mesh Conversion 10 November 20, 2014 10:14
[Commercial meshers] How to get rid of internal walls (surfaces)? bmikuz OpenFOAM Meshing & Mesh Conversion 17 December 5, 2013 16:24
[ICEM] Pyramid elements near internal walls Mohankumarg12 ANSYS Meshing & Geometry 0 June 6, 2013 06:26
[Other] How to create zero thickness internal walls in a given mesh in OpenFOAM? karkar OpenFOAM Meshing & Mesh Conversion 1 July 9, 2012 05:13
