[snappyHexMesh] SnappyHexMesh not generate mesh first time
Old   August 24, 2008, 07:43
Default SnappyHexMesh not generate mesh first time
Marco Moscaritolo
mavimo is on a distinguished road
Hi, I test snappyHexMesh with tutorial and work fine, after that I'm starting to test it with another object into domain.
Mesh generation
On web I find a diablo *.lwo model, with blender i generate stl (using script posted by Andrew Kink ad address http://www.cfd-online.com/OpenFOAM_D...5095#POST25114 ).
After first stl generation i check stl with admesh and using it to correct error on mesh and move it; now I have my correct STL model.
Case setting
After STL creation I genereate a simple domain with blockMesh (no boundary specs, now I'm just check mesh creation), and write my /system/snappyHexMeshDict where I specificate info for mesh creation (see link on bottom for complete case)
Problem description
If I run snappyHexMesh it fall after some step, and not complete the mesh generation. I try to enable debug function into snappyHexMeshDict (debug = 1) and it write mesh for time 2 and 3, and after still fails, but if I restart snappyHexMesh after first time (if debug = 1) it complete mash generation without problem (start from last time step write on case directory)
I test it with different mesh refinement, and into every case error occur (on different time step for every case, in accord with mesh refinement specs).
Case download:
You can find my case (with stl generate and correct) on address:
http://www.cfditalia.org/files/tmp/diablo.tar.gz
Run it:
tar -xzf diablo.tar.gz
blockMesh -case diablo
checkMesh -case diablo
snappyHexMesh -case diablo # error (write some time step)
snappyHexMesh -case diablo # generate emsh
Someone can explain me where's my error? Why if first time fall after work fine? I think problem is on saving data, after saving some info change (approximate points position?) and when restart work fine.
Thanks in advance
Marco
PS. sorry for my bad english :P
mavimo is offline   Reply With Quote
Old   August 24, 2008, 15:44
Default other info I use OpenFOAM 1.5
Marco Moscaritolo
other info
I use OpenFOAM 1.5 32bit on AMD 1.7GHz / 512MB ram with Linux Ubuntu 8.04.
Alberto P write me this case work fine with OF1.5 64bit
Old   August 25, 2008, 18:16
Default Same problem here: openSUSE 1
jfb
Josef F. Buergler
jfb is on a distinguished road
Same problem here:
openSUSE 10.3 on Sun Ultra M2 (64bit) with OpenFOAM 1.5 patched: runs fine
openSUSE 10.3 on IBM T43p (32bit) with OpenFOAM 1.5 patched: same behaviour as mentioned by Marco Moscaritolo
jfb is offline   Reply With Quote
Old   August 26, 2008, 05:14
Default I ran your case in 64 bit and
Mattijs Janssens
mattijs is on a distinguished road
I ran your case in 64 bit and 32 bit mode. Both meshing runs complete without problems.
Why do you have minimum pyramid volume set to 1e-3? This is quite a large value compared to the cell volumes so leaves very little scope to the snapper to morph to your surface.
mattijs is offline   Reply With Quote
Old   August 26, 2008, 08:08
Default @Mattijs: this is a sample to
Marco Moscaritolo
@Mattijs: this is a sample to study snappyHexMesh tool, this mesh is not a fine mesh (I have other snappyHexMeshDict with param for fine mesh), but my primary problem is into mesh creation error.
Bye
Marco
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 42 May 8, 2024 00:17
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
