[surface handling] How to make boundary patches in STL file
Old   August 29, 2008, 03:48
Default How to make boundary patches in STL file
Ning Yang
nzy102 is on a distinguished road
Hello:
First, thank openfoam team for the wondful tool snappyhexmesh. I am working on meshing a quite geometry now. I made the geometry from solidworks. Then converted the solidworks file to STL. The problem with solidworks is it exported the geometry as a whole surface. So I couldn't make patches in the stl file. As a workaround, I imported the stl file in Rhino and saved every surface (patch) as a stl file in ASCII format. Then I put all the stil files together (integrated stl file). When I ran snappyhexmesh, I got something like:
Shell **** does not support testing for inside
Probably it is not closed
I went back to open the integrated stl file in several different softwares ( blender, rhino and solidworks) and it looked that the stl file is closed. Does anybody here has a similar problem?
Is there any other way to makes patches for STL files in general?
Thank you so much.
nzy102 is offline   Reply With Quote
Old   August 29, 2008, 05:48
Default To use inside/outside we requi
Mattijs Janssens
mattijs is on a distinguished road
To use inside/outside we require every edge to have exactly two faces using it. Load in paraview, Filter->Feature Edges and switch on the 'non-manifold' edges. Disable all sharp angle ones (by setting angle to 180?).
mattijs is offline   Reply With Quote
Old   August 29, 2008, 14:53
Default Hi Mattijs: It gave me the
Ning Yang
Hi Mattijs:
It gave me the same error.
Ning
Old   January 8, 2015, 08:56
Default Close stl file
Julie Correncon
CoSponge is on a distinguished road
have you checked if every single solid has the exact syntax? I mean this one:
solid <name>
facet normal 0 1 0
outer loop
vertex -0.019754 -0.15 0.103129
vertex -0.02 -0.15 0.1
vertex -0.019754 -0.15 0.096871
endloop
endfacet
endsolid
Maybe you miss "endsolid" at the end while putting everything toghether. Let me know
Cheers
Julie
CoSponge is offline   Reply With Quote
Old   January 22, 2018, 16:03
Çağatay Emre Ayhan
Cagatayemre is on a distinguished road
I have just used SolidWorks to create stl and boundary patches. But in stl file there are the following lines
solid cylinder_small
facet normal 6.752258e-002 0.000000e+000 -9.977177e-001
outer loop
vertex -1.000000e-001 -5.000000e-004 -1.000000e-002
vertex -9.898832e-002 5.000000e-004 -9.948693e-003
vertex -9.898832e-002 -5.000000e-004 -9.948693e-003
endloop
endfacet
6.752258e-002
-9.977177e-001
I think these numbers creates problem in snappyHexMesh process. Maybe we should try another software to create geometry and mesh such as Salome. Any help will be appreciated.
Cagatayemre is offline   Reply With Quote
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 04:50
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 17:18
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
