[Commercial meshers] CheckMesh error after fluent3DToFoam
Old   September 17, 2008, 04:41
Default CheckMesh error after fluent3DToFoam
luca_phi
I'm trying to convert a Fluent file created with Hypermesh into OpenFoam format.
Typing $ dos2unix <filename.msh(.cas)> no problem.
Typing $ fluent3DToFoam <filename.msh(.cas)> I have no problem, all the files into ./constant/polyMesh/ have been created.
But when I check the mesh with the command $ checkMesh I get this error:
Create time
Create polyMesh for time = constant
Time = constant
#0 Foam::error::printStack(Foam::ostream&) in "/home/openfoam/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/home/openfoam/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 __restore_rt at sigaction.c:0
#3 Foam::primitiveMesh::calcCells(Foam::List<foam::ce ll>&, Foam::UList<int> const&, Foam::UList<int> const&, int) in "/home/openfoam/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 Foam::primitiveMesh::cells() const in "/home/openfoam/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#5 __gxx_personality_v0 in "/home/openfoam/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/checkMesh "
#6 main in "/home/openfoam/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/checkMesh "
#7 __libc_start_main in "/lib64/libc.so.6"
#8 Foam::regIOobject::readIfModified() in "/home/openfoam/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/checkMesh "
Segmentation fault
I get the slightly different error when I type the command $ foamToVTK for converting the files into paraview format.
Can anyone help me to resolve the problem?
Thanks
[Other] CheckMesh vs CheckMesh -allGeometry -allTopology Nagesh Atreyas OpenFOAM Meshing & Mesh Conversion 2 June 25, 2019 05:55
[Technical] checkMesh states that faces do not form a cell, mesh appears correct assert OpenFOAM Meshing & Mesh Conversion 3 December 7, 2015 12:14
checkMesh / mesh errors andybond13 OpenFOAM Pre-Processing 0 June 10, 2015 14:05
[mesh manipulation] checkMesh Erros after refineMesh mgdenno OpenFOAM Meshing & Mesh Conversion 10 October 14, 2014 06:16
checkMesh Errors after refineMesh mgdenno OpenFOAM 0 July 30, 2012 22:39
