[snappyHexMesh] SnappyHexMesh and location in background mesh |
September 25, 2008, 11:40 |
Dear all,
I have been trying to construct a blockmeshdict that specifies a box with airinlet and waterinlet wateroutlet and airoutlet. this acctually consists of two blocks, one on top of the other: verticies( (-50.11 -20.23 -30) //0 (-50.11 20.23 -30) //1 (-50.11 -20.23 0) //2 (-50.11 20.23 0)//3 (-50.11 -20.23 30)//4 (-50.11 20.23 30)//5 (50.12 -20.23 -30)//6 (50.12 20.23 -30)//7 (50.12 -20.23 0)//8 (50.12 20.23 0)//9 (50.12 -20.23 30)//10 (50.12 20.23 30)//11 ) blocks ( hex (0 1 3 2 6 7 9 8) (50 20 30) simpleGrading (0.5 0.2 1) hex (2 3 5 4 8 9 11 10) (50 20 30) simpleGrading (0.5 5 1) ) and i have patches like this: patches ( wall walls ( (0 1 7 6) (0 6 8 2) (2 8 10 4) (1 7 9 3) (3 9 11 5) (4 5 11 10) ) patch win ( (0 1 3 2) ) patch ain ( (2 3 5 4) ) patch wout ( (6 7 9 8) ) patch aout ( (8 9 11 10) ) ); now this all looks good and i get the impression that i only end up with one region (i.e. that the patch between is erased and not there). when i then run snappyHexMesh specifying the position by: locationInMesh (0.12 10.1 -5.252); what happens is that it all runs well and i get: Found point (0.12 10.1 -5.252) in cell 15683 in global region 0 out of 2 regions. Keeping all cells in region 0 containing point (0.12 10.1 -5.252) and when i look at the object (a boat) it is located at the bottom of the top block. what to do? i would like to place it somewhere in between the two blocks and let water flow by it. what am i doing wrong? i think it might just be a matter of a stupid mistake but i can not find it now. thank you Erik Ekedahl |
September 25, 2008, 14:32 |
Hello Erik,
good to see, th
Axel Mohr
Rep Power: 17 |
Hello Erik,
good to see, that I am not alone ;-) My blockMeshDict is similar to yours, 12 vertices and 2 blocks. snappyHexMesh identifies these mesh as only one region, without any internal patch. Is it possible, that your locationInMesh lies inside of the object? If I choose a value like this, two regions are found by snappyHexMesh - but the resulting mesh only contains of a mesh of the object. The location of an object according to the block is controlled by its coordinates - or by the coordinates of the block. So the best way is to choose the coordinates of the block in hexMeshDict so, that it is placed around the block(s). Another thing: I have found that snappyHexMesh seems to prefer aspect ratios of about 1. So I don't use any gradings - for me this works much better, especially with complex geometries. Hope this would help. Greetings, Axel |
September 26, 2008, 04:00 |
i know, it is good! http://www
i know, it is good!
allright, anyways, thank you! i was not using an aspect ratio of 1 now will try that in a moment. i did on the other hand just change a bit in the blockmeshdict so that the bottom box is a bit larger than the top one (i.e. instead of -30 0 and 30 in z-axis i used -30 5 30) and now i got something that looks like a better setup. i think in fact that no matter what the stl-object snaps to origo in the z-direction, which for me makes no sense but using the setup i just mentioned it might work anyway. did you get you case running? i'm pondering on what BC to use for pressure on the waterinlet/outlet. hope thing goes well and thank you for your advice! Erik |
March 22, 2009, 10:16 |
Gmsh+snappyHexMesh
Dear all,
It's great to see your discussions. I have tested the motorBike case, and I have some idea about it. Now I'd like to implement my simple case: uniform around a cylinder(2D case). 1. I use blockMesh to generate coarse mesh for a domain(4000*2000*1 micrometer), i.e. x: -2000~2000, y:0~2000, z:0~1; Uniform mesh along x-, y- direction. X-direction has 200 cells, y- has 100 cells, and z- has 1 cell; (This means the coarse mesh size is 20 micrometer) 2. I use Gmsh to build the STL format. Now I have 2 questions: a. Since we need the surface information about the cylinder(object), should I output STL file after I generate 2D mesh or 3D mesh? b. After Gmsh generates STL information, I could see that there are only "solid Created by Gmsh" and "endsolid Created by Gmsh", Can I define different patch names for the cylinder(front, back, cylinder_surface, and cylinder_axis)? 3. As we could see from: http://www.opencfd.co.uk/openfoam/do...#x26-1480005.4, in snappyHexMesh utility, there must be at least one intersection of a cell edge with the STL surface, i.e. a mesh of one cell will not work. Now my cylinder radius is 1 micrometer, so this means in order to use snappyHexMesh, I must use a background cell which is smaller than 1 micrometer? Thank you for your attention. Bin |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 18:16 |
[snappyHexMesh] Snappyhexmesh removes wrong section of the mesh | robboflea | OpenFOAM Meshing & Mesh Conversion | 0 | April 11, 2019 14:40 |
[snappyHexMesh] Failed 10 mesh checks after snappyHexMesh | jet_engine | OpenFOAM Meshing & Mesh Conversion | 9 | November 21, 2016 14:37 |
[OpenFOAM] snappyHexMesh - can't open mesh in ParaView | tfigueiro | ParaView | 0 | June 11, 2015 20:05 |
[snappyHexMesh] SnappyHexMesh: How to cut a nozzle out of a solid block, and mesh both | MarcusNHofer | OpenFOAM Meshing & Mesh Conversion | 0 | April 6, 2015 11:45 |
