[mesh manipulation] BlockMesh cellSet refineMesh
Like Tree17Likes
Old   August 29, 2019, 16:47
Ali Shayegh
amuzeshi is on a distinguished road
Originally Posted by zp_chem View Post
Hi:
I want to konw have you solved this problem?
Hi.
Who are u talking with?
amuzeshi is offline   Reply With Quote
Old   April 7, 2020, 10:32
amir mofakham
amir.mofakham is on a distinguished road
I just want to add if you want to use refineMesh more than one time make sure to set the startFrom in controlDict to latestTime. Because each time refineMesh creates a mesh at a new time step and if startFrom is not set to latestTime refineshMesh does not read the refined mesh.
Cheers.
Originally Posted by nlinder View Post
Yes i use a script.
You need several cellSet files called cellSetDict.1, cellSetDict.2 .... I created them manually.
Then I use the following script (credits to the one who wrote it, I actually don't know)
refineMeshByCellSet()
   while [ $# -ge 1 ]
   do
      echo "creating cell set for primary zone - $1"
      cp system/cellSetDict.$1 system/cellSetDict
      cellSet > log.cellSet.$1 2>&1
      echo "refining primary zone - $1"
      refineMesh -dict -overwrite > log.refineMesh.$1 2>&1
      shift
   done
runApplication blockMesh
echo "BlockMesh finish"
refineMeshByCellSet 1 2 3
echo "refineMeshByCellSet finish"
The second last line defines how often it will be refined..
Greetings
amir.mofakham is offline   Reply With Quote
[blockMesh] Multi-region Blockmesh - Refinemesh issues. Doug68 OpenFOAM Meshing & Mesh Conversion 3 February 18, 2016 21:09
[blockMesh] Multi-region Blockmesh - Refinemesh issues. Doug68 OpenFOAM Meshing & Mesh Conversion 0 February 17, 2016 04:39
[mesh manipulation] multiple calls to refineMesh parallel w/ dict failing Regis_ OpenFOAM Meshing & Mesh Conversion 2 June 4, 2015 14:44
[mesh manipulation] refineMesh from a cellSet issue gfilip OpenFOAM Meshing & Mesh Conversion 0 September 28, 2010 14:14
Bug in mesh tools: cellSet, refineMesh, ...? alexm OpenFOAM Bugs 0 August 10, 2009 13:46
