[mesh manipulation] BlockMesh cellSet refineMesh
Like Tree17Likes
Old   April 10, 2014, 13:50
Nadish Saini
90nash is on a distinguished road
I had created a tetrahedral mesh and want to refine the whole mesh. I looked through the code of refineMesh and from what I understand it runs for hexahedral mesh only. . Is that so?
90nash is offline   Reply With Quote
Old   April 11, 2014, 04:36
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
Actually you can refine along x and y but not along z. That's what the refineMeshDict is for.
In the source folder of refineMesh you find a commented version of the dictionary. This is the case for most utilities in OpenFOAM.
So, check out $FOAM_APP/utilities/mesh/manipulation/refineMesh
GerhardHolzinger is offline   Reply With Quote
Old   May 30, 2014, 16:31
Post problems with refinemesh
  #23
David Fuentes
fondexx is on a distinguished road
hi I´m new in openFoam, I´m trying to model a vessel to find the resistance coefficients, using the snappyhexmesh, I have some problems to make a refinement in the box where the ship should go using refinemesh but I can´t do it, need some help
fondexx is offline   Reply With Quote
Old   May 30, 2014, 17:49
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi David,
Welcome to the forum.
First of all, please do no double or triple post almost identical questions across multiple theads. Secondly, you do not describe what you have tried and how you have failed. Please read the following link, as it will make your succes on forum more probable:
http://www.cfd-online.com/Forums/ope...-get-help.html
Kind regards,
Niels
fondexx likes this.
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   June 2, 2014, 13:41
Default refining region inside blockMesh
  #25
sandy
sandy13 is on a distinguished road
Originally Posted by idefix View Post
do you want to refine your whole mesh or only a part?
Dear indefix,
I saw your post and I think you can help me. I am using OF2.1.1. I am using blockMesh to generate mesh and now I want to refine a specific region inside it... so what should I get or do.. please any help because I am so confused
best regards,
Sandy13,
sandy13 is offline   Reply With Quote
Old   June 5, 2014, 02:13
idefix is on a distinguished road
Hello Sandy13,
could you give me some more information?
how is the grid looking like and the area you want to refine?
See you
idefix
idefix is offline   Reply With Quote
Old   June 5, 2014, 12:02
sandy
Hello Sandy13,
See you
idefix
Dear Idefix,
Thank you so much for accepting to help me. The mesh is as in the posted picture. I have a long cuboid domain and I want to simulate liquid jet coming from a circular patch from top to bottom through the domain. because I need a high resolution around the liquid through the domain, I want to to refine a specific region along the all domain just a bit bigger than the diameter of the circular patch, so I do not have to increase the mesh all over the domain which runs my case very slow. I tried blockMeshDG but still not that efficient, I want some thing like what snappyHexMesh has... refinementRegions but works on block dict. If you have any syfisticated way to do please help me. I attched my blockMesh file as well..
best wishes,
Sandy13,
amolrajan likes this.
Old   June 10, 2014, 17:07
am I wrong or did you forget to upload the blockMesDict?
Do you have any access to ICEM CFD?
Did I understand it correct that you want to refine a volume which has the shape of a hollow cylinder?
Greetings
idefix
Old   June 18, 2014, 05:10
sandy
Greetings
idefix
Dear idefix,
I am sorry, it was my fault, I did not upload, so here we go below my blockMesh details. What I want exactly is to refine region in the centre has the same height of my domain(z-axis) but the smaller in the length and width(x and y axis).
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1.0;
vertices
(-0.00106 -0.00106 0)//0 // points 0-7 for centerral hex
(0.00106 -0.00106 0)//1
(0.00106 0.00106 0)//2
(-0.00106 0.00106 0)//3
(-0.00106 -0.00106 0.2625)//4
(0.00106 -0.00106 0.2625)//5
(0.00106 0.00106 0.2625)//6
(-0.00106 0.00106 0.2625)//7
(0.00106 0.005 0)//8 // thes points relevent for the back hex
(-0.00106 0.005 0)//9
(0.00106 0.005 0.2625)//10
(-0.00106 0.005 0.2625)//11
(-0.005 0.005 0)//12 // thes points relevent for back left hex
(-0.005 0.00106 0)//13
(-0.005 0.005 0.2625)//14
(-0.005 0.00106 0.2625)//15
(-0.005 -0.00106 0)//16 // thes points relevent for left hex
(-0.005 -0.00106 0.2625)//17
(-0.005 -0.005 0)//18 // thes points relevent for front left hex
(-0.00106 -0.005 0)//19
(-0.005 -0.005 0.2625)//20
(-0.00106 -0.005 0.2625)//21
(0.00106 -0.005 0)//22 // thes points relevent for front hex
(0.00106 -0.005 0.2625)//23
(0.005 -0.005 0)//24 // thes points relevent for front right hex
(0.005 -0.00106 0)//25
(0.005 -0.005 0.2625)//26
(0.005 -0.00106 0.2625)//27
(0.005 0.00106 0)//28 // thes points relevent for right hex
(0.005 0.00106 0.2625)//29
(0.005 0.005 0)//30 // thes points relevent for back right hex
(0.005 0.005 0.2625)//31
blocks
hex (0 1 2 3 4 5 6 7) (8 8 800) simpleGrading (1 1 1) //0 centeral hex
hex (3 2 8 9 7 6 10 11) (8 8 800) simpleGrading (1 1 1) //1 back center
hex (3 9 12 13 7 11 14 15) (8 8 800) simpleGrading (1 1 1) //2 back left corner
hex (0 3 13 16 4 7 15 17) (8 8 800) simpleGrading (1 1 1) //3 left center
hex (0 16 18 19 4 17 20 21) (8 8 800) simpleGrading (1 1 1) //4 front left corner
hex (1 0 19 22 5 4 21 23) (8 8 800) simpleGrading (1 1 1) //5 front
hex (1 22 24 25 5 23 26 27) (8 8 800) simpleGrading (1 1 1) //6 front right corner
hex (2 1 25 28 6 5 27 29) (8 8 800) simpleGrading (1 1 1) //7 right
hex (2 28 30 8 6 29 31 10) (8 8 800) simpleGrading (1 1 1) //8 back right corner
edges
arc 2 3 (0.0 0.0015 0)
arc 3 0 (-0.0015 0.0 0)
arc 0 1 (0.0 -0.0015 0)
arc 1 2 (0.0015 0.0 0)
arc 6 7 (0.0 0.0015 0.2625)
arc 7 4 (-0.0015 0.0 0.2625)
arc 4 5 (0.0 -0.0015 0.2625)
arc 5 6 (0.0015 0.0 0.2625)
boundary
outlet
type patch;
faces
(0 3 2 1)
(2 3 9 8) //lower patches
(3 13 12 9)
(3 0 16 13)
(0 19 18 16)
(0 1 22 19)
(1 25 24 22)
(1 2 28 25)
(2 8 30 28)
inlet
type patch;
faces
(4 5 6 7)
walls
type patch;
faces
(13 15 14 12) //left wall
(16 17 15 13)
(18 20 17 16)
(18 19 21 20) // front
(19 22 23 21)
(22 24 26 23)
(24 25 27 26) //right
(25 28 29 27)
(28 30 31 29)
(12 14 11 9) //back
(9 11 10 8)
(8 10 31 30)
(7 6 10 11) // upper patches
(7 11 14 15)
(4 7 15 17)
(4 17 20 21)
(5 4 21 23)
(5 23 26 27)
(6 5 27 29)
(6 29 31 10)
mergePatchPairs
thanks again for helping me.
Best wishes,
Sandy13
Old   June 19, 2014, 05:15
Dear Sandy13,
thanks for the information. I assumed that the cylinder in the middle is not hollow.
What I did is the following:
I created a cylinderInner.stl-file with the geometry of the cylinder. Inside thise cylinder the cells will be refinded. If you do it, you must be careful. I don´t know why but only if the normals of the surfaces point outside the refinement later will work.
Put the file cylinderInner.stl in your case-folder (like constant and system).
Use the command:
insideCells cylinderInner.stl innerSet
(the name innerSet is chosen from me)
If there is a problem in this step, create a folder "sets":
constant/polyMes/sets
then try it again
now there is a new cell set in constant/polyMesh/sets which is called "innerSet"
you can look at it with:
foamToVTK -cellSet innerSet
or
foamToVTK -constant -cellSet innerSet
now you need the file refinementMesh in system:
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object refineMeshDict;
// Cells to refine; name of 'cellSet'
set innerSet;
// Type of coordinate system:
// - global : coordinate system same for every cell. Usually aligned with
// x,y,z axis. Specify in globalCoeffs section below.
// - patchLocal : coordinate system different for every cell. Specify in
// patchLocalCoeffs section below.
coordinateSystem global;
// Specifies 2 directions by a name and a vector. The normal direction is
// calculated as tan1^tan2
globalCoeffs
//Verfeinerung in x-Richtung
tan1 ( 1 0 0 );
tan2 ( 0 1 0 );
// Verfeinerung in y-Richtung
// tan1 ( 0 1 0 );
// tan2 ( 1 0 0 );
// Verfeinerung in z-Richtung
// tan1 ( 0 0 1 );
// tan2 ( 0 1 0 );
patchLocalCoeffs
// Normal direction is face normal of zero'th face of patch
patch outside;
tan1 ( 1 0 0 );
tan2 ( 0 0 1 );
// Specifies the direction to be refined by the name used above
// To refine in the third direction, use the keyword 'normal'
directions
tan1
tan2
normal
// Whether to use hex topology. This will
// - if patchLocal: all cells on selected patch should be hex
// - split all hexes in 2x2x2 through the middle of edges.
useHexTopology yes;
// Cut purely geometric (will cut hexes through vertices) or take
// topology into account. Incompatible with 'useHexTopology'
geometricCut no;
// Write meshes from intermediate steps
writeMesh no;
here:
set innerSet;
you have to use the same name as the cellSet (created with "insideCells ...")
in the next step just use
refineMesh –dict
a new time step will be created which contains your new grid.
The refineMeshDict refines the cells in every direction. If you just want to refine in one direction you have to change it.
If you want to refine the cells several time I suggest that you use at a first step a bigger cylinder for the first refinement. For the second refinement use a smaller cylinder. Otherwise the cells don´t look nice any more.
I hope it helps, otherwise feel free to ask again.
I had to zip the *.stl file because otherwise I couldn´t upload it.
See you
idefix
Milad06 and amolrajan like this.
Old   June 19, 2014, 11:18
sandy
sorry this was doubled - I don´t know where to delete
Dear idefix,
Thank you very much for supporting me, I do not know how to thank you, I will try the suggestion you posted to me and let you know If I had success..
best wishes,
Sandy13,
Old   June 19, 2014, 11:43
sandy
Dear Sandy13,
Use the command:
then try it again
or
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
set innerSet;
globalCoeffs
tan1 ( 1 0 0 );
tan2 ( 0 1 0 );
// tan1 ( 0 1 0 );
// tan2 ( 1 0 0 );
// tan1 ( 0 0 1 );
// tan2 ( 0 1 0 );
patchLocalCoeffs
patch outside;
tan1 ( 1 0 0 );
tan2 ( 0 0 1 );
directions
tan1
tan2
normal
useHexTopology yes;
geometricCut no;
writeMesh no;
here:
set innerSet;
refineMesh –dict
See you
idefix
Daer idefix,
I tried to do as you told me exactly. So I saved the the stl file you done and saved it in both constant and systemfolder, then ran the command you sent after blockMesh, but I got this error message
Create time
Create polyMesh for time = 0
Reading surface from "cylinderInner.stl"
--> FOAM FATAL ERROR:
Cannnot read "cylinderInner.stl"
From function triSurface::read(const fileName&, const word&, const bool)
in file triSurface/triSurface.C at line 369.
FOAM exiting
Then I did sets folder inside poly folder and put the stl file you sent as you said and ran the same command but it did not run and I got the same error message. I am using OF2.1.1 version. As the error message says I need to red this file from triSurface, so inside constant folder I done triSurface and put the stl file, but still I get the same error message when I run the command you sent.. Do you please have any solution?
best wishes,
Sandy13,
Old   June 19, 2014, 12:12
sandy
Originally Posted by sandy13 View Post
Daer idefix,
Create time
FOAM exiting
best wishes,
Sandy13,
Dear idefix,
Okay - prolbem solved
the STL has to be in the "case" diroctory. Not in the triSurface.
best wishes,
Sandy13,
Old   June 20, 2014, 10:22
sandy
Dear idefix,
best wishes,
Sandy13,
Dear idefix,
I tried using the method you suggested, It works very well, but not as I want because this utility refine the all mesh across the all domain not like I want. I want to refine just a cuboid smaller than my domain inside it and keep the rest of mesh as it is. Please help me if you have any Idea...
best wishes,
Sandy13
Old   August 19, 2014, 05:54
Albrecht vBoetticher
vonboett is on a distinguished road
Hi Sandy,
the magic is in
set innerSet;
when using refineMesh. You can create all kinds of cellSets to select the cells you want to refine, for example only choosing certain cells that contain a certain range of flow velocity or pressure, by using topoSet. once you have created a cellSet with topoSet that contains the cells you want to refine, you can control wether you want to split the cells in x, y or x y and z directions in the refineMeshDict dependent on the presence of tan1, tan2 and normal in
directions
tan1 // x
tan2 // y
normal // z
But you have to be aware that you call refineMesh as 'refineMesh -dict system/refinemeMeshDict' in OF 2.3
fsifsi likes this.
vonboett is offline   Reply With Quote
Old   February 8, 2016, 10:31
ok
Maimouna is on a distinguished road
Hi all,
in the attached picture, I have two blockMeshDict file one for fluid and another for solid as following
|  \\    /   O peration     | Version:  2.2.2                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
convertToMeters 1;//dimensions in meters --> conversion 1
vertices
(0 0 0) //vertex 0
(5 0 0) //vertex 1
(6 0 0) //vertex 2
(10 0 0)//vertex 3
(20 0 0) //vertex 4
(0 4 0) //vertex 5
(5 4 0) //vertex 6
(6 4 0)//vertex 7
(10 4 0) //vertex 8
(20 4 0) //vertex 9
(0 7 0) //vertex 10
(5 7 0)//vertex 11
(6 7 0) //vertex 12
(10 7 0) //vertex 13
(20 7 0) //vertex 14
(0 11 0)//vertex 15
(5 11 0) //vertex 16
(6 11 0) //vertex 17
(10 11 0) //vertex 18
(20 11 0)//vertex 19
(0 0 11) //vertex 20
(5 0 11) //vertex 21
(6 0 11) //vertex 22
(10 0 11)//vertex 23
(20 0 11) //vertex 24
(0 4 11) //vertex 25
(5 4 11) //vertex 26
(6 4 11)//vertex 27
(10 4 11) //vertex 28
(20 4 11) //vertex 29
(0 7 11) //vertex 30
(5 7 11)//vertex 31
(6 7 11) //vertex 32
(10 7 11) //vertex 33
(20 7 11) //vertex 34
(0 11 11)//vertex 35
(5 11 11) //vertex 36
(6 11 11) //vertex 37
(10 11 11) //vertex 38
(20 11 11)//vertex 39
blocks
hex (0 1 6 5 20 21 26 25) (20 15 20) simpleGrading (1 1 1) //block 0
hex (1 2 7 6 21 22 27 26) (20 15 20) simpleGrading (1 1 1) //block 1
hex (2 3 8 7 22 23 28 27) (20 15 20) simpleGrading (1 1 1) //block 2
hex (3 4 9 8 23 24 29 28) (20 15 20) simpleGrading (1 1 1) //block 3
hex (5 6 11 10 25 26 31 30) (20 15 20) simpleGrading (1 1 1) //block 4
hex (6 7 12 11 26 27 32 31) (20 15 20) simpleGrading (1 1 1) //block 5
hex (7 8 13 12 27 28 33 32) (20 15 20) simpleGrading (1 1 1) //block 6
hex (8 9 14 13 28 29 34 33) (20 15 20) simpleGrading (1 1 1) //block 7
hex (10 11 16 15 30 31 36 35) (20 15 20) simpleGrading (1 1 1) //block 8
hex (11 12 17 16 31 32 37 36) (20 15 20) simpleGrading (1 1 1) //block 9
hex (12 13 18 17 32 33 38 37) (20 15 20) simpleGrading (1 1 1) //block 10
hex (13 14 19 18 33 34 39 38) (20 15 20) simpleGrading (1 1 1) //block 11
edges
patches
patch top
(0 5 6 1)
(3 8 9 4)
(5 10 11 6)
(8 13 14 9)
(10 15 16 11)
(11 16 17 12)
(12 17 18 13)
(13 18 19 14)
patch bottom
(20 25 26 21)
(23 28 29 24)
(25 30 31 26)
(28 33 34 29)
(30 35 36 31)
(31 36 37 32)
(32 37 38 33)
(33 38 39 34)
patch output //right
(19 14 34 39)
(14 9 29 34)
(9 4 24 29)
patch input //left
(15 10 30 35)
(10 5 25 30)
(5 0 20 25)
patch cylinder
(1 6 7 2)
(6 11 12 7)
(21 26 27 22)
(26 31 32 27)
wall plate
(2 7 8 3)
(7 12 13 8)
(22 27 28 23)
(27 32 33 28)
patch frontPlane
(0 1 21 20)
(1 2 22 21)
(2 3 23 22)
(3 4 24 23)
patch backPlane
(15 16 36 35)
(16 17 37 36)
(17 18 38 37)
(18 19 39 38)
mergePatchPairs
solid
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
vertices
    (6 0 0) //vertex 0
    (10 0 0)//vertex 1
    (6 4 0)//vertex 2
    (10 4 0) //vertex 3
    (6 7 0) //vertex 4
    (10 7 0) //vertex 5
    (6 0 11) //vertex 6
    (10 0 11)//vertex 7
    (6 4 11)//vertex 8
    (10 4 11) //vertex 9
    (6 7 11) //vertex 10
    (10 7 11) //vertex 11
blocks
      hex (0 1 2 3 4 5 6 7) (20 15 20) simpleGrading (1 1 1)
    //hex (2 3 8 7 22 23 28 27) (20 15 20) simpleGrading (1 1 1) //block 2
    //hex (7 8 13 12 27 28 33 32) (20 15 20) simpleGrading (1 1 1) //block 6
edges
patches
     patch plateFix
         (3 7 4 0)
     //patch plate
       wall plate
      (3 2 6 7)
      (6 2 1 5)
      (1 0 4 5)
     symmetryPlane frontPlane
     (0 1 2 3)
     symmetryPlane backPlane
     (7 6 5 4)
mergePatchPairs
that because I'm working with FSI (fsiFoam solver).
The thickness of the plate (foil) is 0.06, I would like to refine the mesh near the foil. How could do that? Help me please by write all steps in order to do that.
Lots of thanks in advanced.
Maimouna
File Type: jpg Screenshot from 2016-01-25 16:07:10.jpg (66.2 KB, 70 views)
Maimouna is offline   Reply With Quote
Old   July 6, 2016, 12:48
bangun
eb19 is on a distinguished road
I am using refineMesh to refine the cells locally. But from this refinement, some tetrahedral cells with high skewness are generated. How to get rid of these elements?
Can I maintain the size of the original cells which are adjacent to the refined cells? Attached is the mesh after having been refined. You could see the tetrahedral cells at cell faces between the refined cells (right or upper cells) and the cells not being refined (left cells).
I would imagine if this can be done, eventually i will have some non-conformal cells or maybe some inner faces. This is what I want to have from my mesh. The local refinement but without any tetrahedral cells. Please anyone who had the same problem share your experience here. Thanks.
Best
ebb19
eb19 is offline   Reply With Quote
Old   September 6, 2017, 18:27
bangun
I know this is an old post. Can you tell me how to generate an stl file from the program that idefix attached. I tried saving a file generated by that program in an stl file and I openned the file, but the content of the file is unreadable.
How do we then include this stl file into constant folder of OpenFOAM? I am confused about using this stl file. My intention is to specify a region to be refined. I can not use typical cellSources such as cylindertoCell, boxtoCell, etc because nono of them is exactly as I want. Can you please explain to me how you used the stl file to refine a specific region in your domain?
Old   January 21, 2019, 00:14
Ali Shayegh
amuzeshi is on a distinguished road
Originally Posted by emirust View Post
Tried, but doesnt serve my purpose of increasing the cell resolution in the central part (as seen in screenshot where I ran the utility three times)
A brief manual on refineMesh
Hello There
You've gone the wrong way. Follow the right method on the following, which differs only in one more topoSet.
Present case
As an example, I ran refining on cavity case. I created two sets named mediumCellSet and hiCellSet ; images are attached. We want to refine mediumCellSet less and hiCellSet more.
Wrong method
1- blockMesh
2- topoSet
3- refineMesh (on mediumCellSet)
4- refineMesh (on hiCellSet)
5- Result:wrongMethod.jpg (attached)
Right method
- before step 4 mentioned above, execute a topoSet again.
- Result:rightMethod.jpg (attached)
amuzeshi is offline   Reply With Quote
Old   August 29, 2019, 07:57
zhaopeng
zp_chem is on a distinguished road
Hi:
I want to konw have you solved this problem?
zp_chem is offline   Reply With Quote
[blockMesh] Multi-region Blockmesh - Refinemesh issues. Doug68 OpenFOAM Meshing & Mesh Conversion 3 February 18, 2016 21:09
[blockMesh] Multi-region Blockmesh - Refinemesh issues. Doug68 OpenFOAM Meshing & Mesh Conversion 0 February 17, 2016 04:39
[mesh manipulation] multiple calls to refineMesh parallel w/ dict failing Regis_ OpenFOAM Meshing & Mesh Conversion 2 June 4, 2015 14:44
[mesh manipulation] refineMesh from a cellSet issue gfilip OpenFOAM Meshing & Mesh Conversion 0 September 28, 2010 14:14
Bug in mesh tools: cellSet, refineMesh, ...? alexm OpenFOAM Bugs 0 August 10, 2009 13:46
