[mesh manipulation] Mesh Refinement
Like Tree4Likes
Old   January 16, 2013, 10:58
blackbirdinapie is on a distinguished road
Hi emirust
I tried to find if there is a way, and there really does not appear to be one apart from calling refineMesh every time.
blackbirdinapie is offline   Reply With Quote
Old   January 17, 2013, 03:43
emirust is on a distinguished road
Ok! It serves my purpose, so why not!
Do anyone have an idea on how to automate this? I use topoSet to select a box of cells where I want the refinement, but then I would like to select a smaller box for another refinement, and then another box in this one etc... This has to be repetated maybe 8 times.
I guess the solution is not to use a topoSetDict, but call the utility directly in the command prompt. I was expecting something like this to work:
topoSet thenameoftheset new boxToCell (xmin ymin zmin) (xmax ymax zmax)
but I get an error "syntax error near unexpected token `(' "
Thanks!
emirust is offline   Reply With Quote
Old   January 8, 2017, 13:55
Default patchLocal
  #43
bangun
eb19 is on a distinguished road
Originally Posted by mattijs View Post
you'll need to use
- patchLocalCoeffs
- useHexTopology true
- geometricCut false
And switch on the debug switch for hexCellLooper.
Is your mesh pure hex?
Hi Mattijs,
I know this is an old post. Can you please explain where to switch on the debug switch for hexCellLooper? Is this still valid for OpenFoam v2.3.0?
Another thing is if I want to refine cells alligned with a cylindricalWall in three directions (i.e. normal and vertical directions), how do I define the patchLocal coordinate system in the refineMeshDict?
I've been trying hard to understand the description in the OpenFoam wiki but I still don't get it.
Best
Ebb
eb19 is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 10:12
y+ = 1 boundary layer mesh with snappyHexMesh Arzed23 OpenFOAM Running, Solving & CFD 6 November 23, 2022 16:15
[snappyHexMesh] Edge Refinement fracasce OpenFOAM Meshing & Mesh Conversion 3 December 2, 2017 14:30
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[snappyHexMesh] problems using snappyHexMesh 2.1.0 on a supercomputer Sunxing OpenFOAM Meshing & Mesh Conversion 9 September 20, 2014 10:30
