[snappyHexMesh] SnappyHexMesh and Snapping
Old   July 25, 2008, 09:51
Default SnappyHexMesh and Snapping
Thomas Ripplinger
thomasr is on a distinguished road
I am trying to mesh a 3D wing with snappyHexMesh. So far I have used the parameters of the motorBike example to operate snappyHexMesh. According to the output of snappyHexMesh everything goes well. However, if I look to the final mesh, the cells at the wing surface are not adjusted (snapped) to the surface (see picture). Which would be the parameter to control this? Is there a tutorial by which snappyHexMesh can be tried out?
Thanks,
Thomas
thomasr is offline   Reply With Quote
Old   July 25, 2008, 09:55
Default Sorry, I missed the point to a
Thomas Ripplinger
Sorry, I missed the point to attach the picture:
Old   February 16, 2009, 09:26
Default in the snappyHexMesh Dict at t
Wolfgang Heydlauff
wolle1982 will become famous soon enough
in the snappyHexMesh Dict at the very top there you have to set the snapcontrol to "true". furthermore you have to switch to timestep 2 and 3 to see the snapped result. the picture you posted seems to be timestep 1.
wolle1982 is offline   Reply With Quote
Old   June 15, 2010, 20:48
Default tutorial one more to check it out
tachyon_me is on a distinguished road
http://www.opencfd.uphero.com/foam_meshing.htm
tachyon_me is offline   Reply With Quote
Old   February 1, 2012, 13:09
Default synappy hex mesh
hhh
kunar
hhh is on a distinguished road
Dear foamers,
i have problem in snappy hex mesh, i have cad model in stl format,how i solve in open foam,
1.how to import
2.how to create outer domain
3.how to mesh the model
4.how to set boundary condition,for my i consider to create domain to set
inlet velocity ,pressure outlet and remaining face is symmetry wall is cad model
5.how to run
i am begineer please give idea for to this problem
hhh is offline   Reply With Quote
Old   March 15, 2012, 12:07
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Originally Posted by hhh View Post
Dear foamers,
1.how to import
5.how to run
1. Import what? The geometry must be inside constant/triSurface
2. using BlockMesh, have a look at the motorbike tutorial for instance;
3. Using snappyHexMesh, again, have a look at the motorbike tutorial;
4. Again… motorbike… also reading the manual would help…probably spending the same amount of time you used to write this post in reading the manual would have helped a lot more…
5. guess what… motorbike and manual…
lovecraft22 is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh not snapping to cylinder end wildfire230 OpenFOAM Meshing & Mesh Conversion 0 March 1, 2019 13:09
[snappyHexMesh] snappyHexMesh: Bad snapping on shallow slopes matthiasd OpenFOAM Meshing & Mesh Conversion 5 February 1, 2017 18:23
[snappyHexMesh] SnappyHexMesh : snapping not matching surface Awak OpenFOAM Meshing & Mesh Conversion 4 May 31, 2016 09:23
[snappyHexMesh] snappyHexMesh doesn't do feature edge snapping wc34071209 OpenFOAM Meshing & Mesh Conversion 1 May 7, 2014 17:47
[snappyHexMesh] SnappyHexMesh - snapping the wrong elements A.Wendy OpenFOAM Meshing & Mesh Conversion 1 September 25, 2012 04:52
