[mesh manipulation] Moving Mesh engineFoam Addremove layer
Old   February 12, 2009, 12:07
Default Moving Mesh engineFoam Addremove layer
gb
gbracing is on a distinguished road
Hi all,
I just started to use OpenFoam a few weeks ago. I performed a few tutorials and now try my own based on engineFoam.
I generated a 3D combustion chamber mesh with gambit and exported it to foam with Piston, CylinderHead and liner patches. I rerun the engineFoam tutorial and the mesh is moving well but I would like to be able to automaticaly add/remove layers in order to avoid as much as possible the mesh deformation which leads to CFL crashes...
Any Idea ?
Thanks for your help
greg
gbracing is offline   Reply With Quote
Old   February 18, 2009, 05:35
Default I've found layeredEngineMesh i
Benjamin Berger
gizmo is on a distinguished road
I've found layeredEngineMesh in the engineMesh utilities and I'm trying to use it with dieselEngineFoam. Maybe this could help you to use addition/removal layers methods.
If you find a way to use it, give me your feed back ;-)
Good work and thank you for your help!
gizmo is offline   Reply With Quote
y+ = 1 boundary layer mesh with snappyHexMesh Arzed23 OpenFOAM Running, Solving & CFD 6 November 23, 2022 16:15
[snappyHexMesh] snappyHexMesh - geometry does not appear in Mesh czhongrong OpenFOAM Meshing & Mesh Conversion 1 January 20, 2016 06:26
[ICEM] 3D Dynamic Mesh - Boundary layer mesh issues nathanricks ANSYS Meshing & Geometry 0 September 23, 2015 06:14
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 14:47
