[mesh manipulation] Converting a 2Dmesh to axisymmetric
Like Tree20Likes
Old   June 18, 2013, 12:59
Assistant Moderator
Bernhard Gschaider
Originally Posted by shash View Post
hi bernhard,
I am sorry , i didn't go thru prevoius threads. Thanks a lot for ur answer now its up and running, I also wanted to confirm something, thou collapseEdges 1e-06 175 command after makeaxialmesh worked for me on OF ver 2.1 but a friend of mine is getting troubles running the same command collapseEdges 1e-06 175 for same case on OF ver 2.2, whats the reason for that, its showing required 0 argument, 2 given
Seems like they changed the way it works. Try the -h option to see if there are options you like. Run without arguments and see what happens. I'm currently on vacation so it might be faster for you if you try some experiments yourself
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   June 19, 2013, 00:43
Yao Lu
shuoxue is on a distinguished road
Hi, gschaider!
It seems that you know much about #0 Foam::error:rintStack error.
I have received this kind of error when running interFoam with Gambit mesh.
Would you please check the error for me. Thanks a lot.
http://www.cfd-online.com/Forums/ope...tml#post434749
I installed openfoam 2.2.0 on ubuntu 12.04.
Best regards.
shuoxue is offline   Reply With Quote
Old   June 20, 2013, 21:15
Assistant Moderator
Bernhard Gschaider
Originally Posted by shuoxue View Post
Hi, gschaider!
Best regards.
printStack can be anything. See http://openfoamwiki.net/index.php/HowTo_debugging on how to interpret it. And I don't answer questions that do not belong in this thread
Old   August 14, 2013, 08:23
Default Error while running ..rhocentralfoam
  #164
sonu
yash.aesi is on a distinguished road
helo ,
i converted my 2D axisymmetry fluent mesh into OF and then changed the 0 folder according to my values also i checked mesh with checkmesh command its ok but when i tried to run it run it is giving me following error , can anybody please help me how to overcome from this error ?
FOAM FATAL IO ERROR:
inconsistent patch and patchField types for
patch type symmetryPlane and patchField type empty
file: /home/yash/OpenFOAM/yash-2.2.0/run/tutorials/compressible/rhoCentralFoam/exsercisePrb/0/p.boundaryField.Axis from line 39 to line 39.
From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&)
in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 165.
yash.aesi is offline   Reply With Quote
Old   August 14, 2013, 10:30
Nima Samkhaniani
nimasam is on a distinguished road
look at the error line, it says:
so you should make those types consistent , if you choose symmetryPlane as patch type, then p, U or other variables should have the same patch type means symmetryPlane not empty
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   August 14, 2013, 15:30
sonu
helo
can you please look into the p file and tell me wts wrong in it which you had mentioned , thanks alot for your reply ,
| \\ / O peration | Version: 2.2.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 101325;
boundaryField
fuel_inlet
type zeroGradient;
coflow_inlet
type zeroGradient;
Outlet
type zeroGradient;
Axis
type empty;
Upperwall
type zeroGradient;
frontAndBack
type empty;
Old   August 14, 2013, 16:34
Nima Samkhaniani
Axis
type empty;
well, it should be
Axis
type symmetryPlane;
also i thing your frontAndBack should be wedge type :P, however you may face this problem next
vivek05 likes this.
Old   August 14, 2013, 16:45
sonu
thanks alot nima. i will try this and then inform you ......thanks again for helping
Old   August 16, 2014, 16:35
ZD
zhixuan is on a distinguished road
hi, all foamers,
I came across problems when using makeAxisMesh in OF2.3.0. Here are steps I went through:
1. run blockMesh, where axis_plane has been set as planar type
2. run makeAxialMesh -axis axis_plane -wedge frontAndback
however, it says
HTML Code:
Symmetry plane 'axis_plane' is not planar.
At local face at (0 -0.075565 0.0025) the normal (0 0 0) differs from the average normal (0.438889 0 0) by 0.192623
Either split the patch into planar parts or use the symmetry patch type
I changed the "axis_plane" to be "symmetric", it still cannot work.
Then I changed the coordinates, such as switching X axis and Y axis, it works somehow with a new error:
HTML Code:
--> FOAM FATAL ERROR:
wedge frontAndback_pos plane aligns with a coordinate plane.
    The wedge plane should make a small angle (~2.5deg) with the coordinate plane
    and the the pair of wedge planes should be symmetric about the coordinate plane.
    Normal of face 0 is (-1 0 0) , implied coordinate plane direction is (-1 0 0)
    From function wedgePolyPatch::initTransforms()
    in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 78.
FOAM exiting
I tired several times rotating the coordinator. But still, nothing improved. So I'm wondering if anyone can provide hints on this issue.
I also enclosed my blockMeshDict for your reference.
Thank you in advance.
luonghungtruyen likes this.
zhixuan is offline   Reply With Quote
Old   August 17, 2014, 18:33
Assistant Moderator
Bernhard Gschaider
Originally Posted by zhixuan View Post
hi, all foamers,
however, it says
HTML Code:
What do you mean with "set as planar type"? The type of the patch is irrelevant. The faces have to be in a plane (that's what "planar" means). That's what the utility checks for. Otherwise the patch can't be used as an axis
Old   August 17, 2014, 19:31
ZD
Hi, Bernhard,
Thank you for the response. Originally, I tried the test case you provided here
http://openfoamwiki.net/index.php/Contrib/MakeAxialMesh
I tried
1. blockMesh
2. makeAxialMesh -axis movingWall -wedge frontAndBack
it generates an error, saying
HTML Code:
Symmetry plane 'movingWall' is not planar.
At local face at (0.00333333 0.1 0) the normal (0 1 0) differs from the average normal (0 0.3 0) by 0.49
    From function symmetryPlanePolyPatch::n()
    in file meshes/polyMesh/polyPatches/constraint/symmetryPlane/symmetryPlanePolyPatch.C at line 64.
FOAM exiting
I'm confused why it says the points on movingWall is not on a planar.
Then I thought it probably due to the wrong direction since you mentioned "the axis of symmetry is parallel to the XY-plane". So I split the fixedWalls into three surfaces and selected different fixedWalls1(0 4 7 3), fixedWalls2(2 6 5 1), fixedWalls3(1 5 4 0) as the axis. Only the fixedWalls2 (2 6 5 1) can work and it is actually parallel to Y-Z plane.
Based on the experience of the test, I developed my own code
FoamFile
    version         2.3;
    format          ascii;
    root            "";
    case            "";
    instance        "";
    local           "";
    class           dictionary;
    object          blockMeshDict;
vertices
	(0 -0.0762  0)   // 0
	(0 -0.0762 0.0079375  ) // 1
	(0 0 0.0079375 )   //2
	(0 0 0.070358 )   //3
	(0 0.1524 0.070358 ) //4
	(0 0.508 0.070358 )  //5
	(0 0.508 0) //6
	(0 0.1524 0)  //7
	(0 0 0) //8
	(0.005 -0.0762 0 )   // 9
	(0.005 -0.0762 0.0079375  ) // 10
	(0.005 0 0.0079375 )   //11
	(0.005 0 0.070358 )   //12
	(0.005 0.1524 0.070358 ) //13
	(0.005 0.508 0.070358 )  //14
	(0.005 0.508 0 ) //15
	(0.005 0.1524 0 )  //16
	(0.005 0 0 ) //17
	(0 0.508 0.0079375 ) //18
	(0.005 0.508 0.0079375 ) //19
	(0 0.1524 0.0079375 ) //20
	(0.005 0.1524 0.0079375 ) //21
blocks
	// process inlet
	hex (0 8 2 1 9 17 11 10) (60 10 1) simpleGrading (1 1 1)
	// burner 1
	hex (8 7 20 2 17 16 21 11) (60 10 1) simpleGrading (1 1 1)
	// burner 2
	hex (2 20 4 3 11 21 13 12) (60 40 1) simpleGrading (1 1 1)
	// burner 3
	hex (20 18 5 4 21 19 14 13) (60 40 1) simpleGrading (1 1 1)
	// burner 4
	hex (7 6 18 20 16 15 19 21) (60 10 1) simpleGrading (1 1 1)
edges
boundary
 	processInlet
            type patch;
            faces
                (0 1 10 9)
	wall
            type wall;
            faces
                (1 2 11 10)
		//(3 2 11 12)
		(12 11 2 3)
	outlet
            type patch;
            faces
                (5 18 19 14)
		(18 6 15 19)
	axis_plane
            type symmetry;
            faces
                //(0 8 17 9)
		(9 17 8 0)
		//(8 7 16 17)
		(17 16 7 8)
		(7 6 15 16)
	quenchingWall
            type wall;
            faces
                (4 5 14 13)
	porousInlet
            type patch;
            faces
                (3 4 13 12)
	frontAndback
            type empty;
            faces
                (0 8 2 1)
		(8 7 20 2)
		(7 6 18 20)
		(2 20 4 3)
		(20 18 5 4)
                (9 17 11 10)
		(17 16 21 11)
		(16 15 19 21)
		(11 21 13 12)
		(21 19 14 13)
mergePatchPairs
However, when I run
it says
HTML Code:
Create time
Create mesh for time = 0
 Using old mode. Dictionary not used
Plane of the grid: (0 0 1) (0.0025 0.180204 0.0294471)
The rotation-axis: ((0 -0.0762 0.0294471) (0.005 0.508 0.0294471))
Creating wedge with an opening angle of 5 degrees
Projecting nodes
Radius to axis: min = 0 max = 0.00499982
Splitting patch frontAndback
 Copying patches
 Creating Patches
 Creating Pos-patch
 Creating Neg-patch
 Changing patches
Changing patch types
 Changing axis_plane to symmetryPlane
 Changing frontAndback_pos to wedge
FOAM exiting
I don't know what's wrong with this error. Again, I rotated the coordinator directions, but nothing is improved.
By the way, I'm using OF2.3.0.
Thank you
Zhixuan
Old   August 21, 2014, 19:48
Assistant Moderator
Bernhard Gschaider
Hi, Bernhard,
I tried
1. blockMesh
HTML Code:
FOAM exiting
Seems like there is some problem when patches are specified on the command line. I get the same error. But when I run it just with "makeAxialMesh" the dictionary in system is used and it works.
I'd recommend using the dictionary anyway as this is more flexible
Old   November 19, 2014, 13:55
Davi Barreira
davibarreira is on a distinguished road
Im facing the same problem as zhixuan. The thing is, even if I use the dictionary by just running the command makeAxialMesh, the "movingWall" keeps it's patch as "wall". Any thoughts?
Thanks!
davibarreira is offline   Reply With Quote
Old   December 19, 2014, 21:55
zhangyan's Avatar
Yan Zhang
zhangyan is on a distinguished road
Thanks!
Hi
Have you solved this problem now?
zhangyan is offline   Reply With Quote
Old   December 20, 2014, 01:45
Davi Barreira
--> FOAM FATAL ERROR:  wedge frontAndback_pos plane aligns with a coordinate plane.     The wedge plane should make a small angle (~2.5deg) with the coordinate plane     and the the pair of wedge planes should be symmetric about the coordinate plane.     Normal of face 0 is (-1 0 0) , implied coordinate plane direction is (-1 0 0)
I managed to solve this problem by using the dictonary rotationDict, and using the option for setting MakeAxialMesh in old version. Below there is a rotationDict with this option turned on:
|  \\    /   O peration     | Version:  1.0                                   |
|   \\  /    A nd           | Web:      http://www.openfoam.org               |
FoamFile
    version         2.0;
    format          ascii;
    root        ".";
    case         "test";
    instance        "system";
    local           "";
    class           dictionary;
    object          radialBCDict;
// Use the same parameters as from the command line
makeAxialOldMode 1;
// used in old and in new mode
makeAxialAxisPatch sym;
makeAxialWedgePatch frontandback;
// used only in old mode
makeAxialOffset 0.01;
// used only in new mode
rotationVector (1 0 0);
originVector (0 0 0); //offset
// originVector (0 0 0); // origin
wedgeAngle 5;
// revolve option
// 0 = old and default mode, points are projected on wedges
// 1 = points are revolved
revolve 0;
I tried using collapseEdges, but I just couldnt get it to work. So I decided to use my mesh with symmetryPlane in the face that was supposed to be the axis (dont know how correct this is, but the results are looking correct when compared to some 3D simulations I ran).
The patch type I had to change manually in my blockMeshDict file.
I played around with MakeAxialMesh for a while and I really think it has some compatibility error with OpenFOAM 2.3, because the errors occur even in really simple meshes.
Old   December 20, 2014, 02:43
zhangyan's Avatar
Yan Zhang
Hi
I also tried rotateMesh ,but I don't know the usage .Can you help me ?
zhangyan@ubuntu:~/0.0$ rotateMesh
Usage: rotateMesh [OPTIONS] <n1> <n2>
options:
  -case <dir>       specify alternate case directory, default is the cwd
  -constant         include the 'constant/' dir in the times list
  -latestTime       select the latest time
  -noFunctionObjects
                    do not execute functionObjects
  -noZero           exclude the '0/' dir from the times list, has precedence
                    over the -zeroTime option
  -parallel         run in parallel
  -roots <(dir1 .. dirN)>
                    slave root directories for distributed running
  -time <ranges>    comma-separated time ranges - eg, ':10,20,40:70,1000:'
  -srcDoc           display source code in browser
  -doc              display application documentation in browser
  -help             print the usage
Old   December 20, 2014, 09:29
Davi Barreira
rotateMesh is not to create axial meshes, if you want to create an axial mesh use makeAxialMesh. Just create the rotationDict as I posted and put it on your system folder. Then run the command makeAxialMesh. This will create a mesh in a folder such as 0.005, or something like that. Use checkMesh command to see if the mesh is correct, then replace your orignal polymesh folder with the one in the 0.005 folder.
Old   December 20, 2014, 09:33
zhangyan's Avatar
Yan Zhang
I also have tried makeaxialMesh.
but ,
FOAM exiting
my movingWall's type is empty, I also tried symmetry and symmetryPlane, but all failed.
Old   December 20, 2014, 09:35
zhangyan's Avatar
Yan Zhang
and another question: rotateDict is used accompany with rotateMesh.
I think makeaxialMesh don't need this dictionary.
Old   December 20, 2014, 09:47
Davi Barreira
The dictionary for makeAxilMesh is rotationDict not rotateDict. Can you post your blockMeshDict here so I can take a look?
Simplest way of converting a 2d Navier Stokes code to a 2d axisymmetric one mseka Main CFD Forum 1 September 18, 2017 15:53
Axisymmetric Boundary condition Mohit Singh SU2 3 July 15, 2015 10:19
[mesh manipulation] Converting axisymmetric mesh into fully 3D mesh tomloh OpenFOAM Meshing & Mesh Conversion 0 April 29, 2012 21:31
Difference of final temperature between a plane and an axisymmetric geometry douchka FLUENT 0 July 7, 2011 09:38
URGENT ! Need help on Axisymmetric Flow ! Suman Kumar Main CFD Forum 1 November 20, 2001 15:51
