[mesh manipulation] Converting a 2Dmesh to axisymmetric |
December 25, 2012, 17:14 |
#141 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
old mode is if you specify axis and wege from the command line and therefor the dictionary is not used. This mode does not allow the axis to have an offset
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
December 26, 2012, 01:34 |
reply
#142 |
vahid
Rep Power: 13 |
Hi, Dear rajeshkunwar.
Your question not Clear for me!!!plz Explain more about your question? maybe i can help you!!! |
December 26, 2012, 01:35 |
#143 |
vahid
Rep Power: 13 |
December 27, 2012, 04:34 |
#144 |
Rajesh Kumar
Rep Power: 17 |
The axis patch type becomes symmetryPlane after using makeAxialMesh in boundary file of polyMesh directory . What boundary type I have to specify in P and U files for symmetryPlane.
December 28, 2012, 17:02 |
#145 |
vahid
Rep Power: 13 |
if you done true all steps,you should have Something similar the following lines in your boundary:
frontAndBackPlanes { type empty; } frontAndBackPlanes_pos { type wedge; } frontAndBackPlanes_neg { type wedge; } are you make this lines(wedge) in your boundary in polymesh file?if you see this,so you should add the above lines in P and U files. |
December 29, 2012, 11:26 |
#146 |
Rajesh Kumar
Rep Power: 17 |
Hi Vahid. Thank you for replying. my boundary file is below. The axis patch name is Axis.
FoamFile { version 2.0; format ascii; class polyBoundaryMesh; location "constant/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 8 ( Axis { type symmetryPlane; nFaces 0; startFace 19800; } Upper_Boundary { type patch; nFaces 100; startFace 19800; } Side_Boundary { type patch; nFaces 100; startFace 19900; } Bottom_Wall { type wall; nFaces 90; startFace 20000; } Source { type patch; nFaces 10; startFace 20090; } frontAndBackPlanes { type empty; nFaces 0; startFace 20100; } frontAndBackPlanes_pos { type wedge; nFaces 10000; startFace 20100; } frontAndBackPlanes_neg { type wedge; nFaces 10000; startFace 30100; } U file in zero folder is below. FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0.0 0 0); boundaryField { Axis { type symmetryPlane; } Upper_Boundary { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } .... I just wanted to confirm whether it is correct or not. |
December 30, 2012, 02:16 |
#147 |
vahid
Rep Power: 13 |
Hi dear rajeshkunwar .
I havent time to see your boundary,but I know that you have to run this line: makeAxialMesh -axis axis -wedge frontAndBackPlane I think, its better for you to learn it, do this Commands for a simple geometry like Rectangular shape!!! if your problem don't solve,Ask the problem again,to explain it!!! |
January 3, 2013, 03:47 |
#148 |
Rajesh Kumar
Rep Power: 17 |
I have done the same thing what you have suggested. My confusion is regarding the boundary condition of Axis patch.
January 5, 2013, 19:05 |
#149 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
The type of the axis patch has been rewritten as this usually causes the least problems. If the axis patch was also the rotation axis then collapseEdges should remove all faces there anyway and the type of it is irrelevant. Otherwise if you don't like symmetryPlane go to constant/polymesh/boundary and change it there
January 11, 2013, 10:25 |
#150 |
Andrea Ferrari
Rep Power: 16 |
Hi all,
where can i download makeAxialMesh for openFoam 2.1.0? svn doesn't work. thanks andrea |
January 11, 2013, 10:52 |
#151 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
I will look into how to make stuff that is undisputed available in the meantime, but probably can't do so before monday If somebody who recently downloaded it (makeAxialMesh) could make a tarball of the source and make it available to the public (for instance on the Wiki) that would be great
January 14, 2013, 07:41 |
#152 |
Andrea Ferrari
Rep Power: 16 |
HI Bernhard,
if you can just copy here makeAxialMesh.C that compiles on OF 2.1.0 i can easily do the rest. I cannot find the source code. Thanks |
January 14, 2013, 08:59 |
#153 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Just added a tar to the MAM-page on the Wiki
January 14, 2013, 10:07 |
#154 |
Andrea Ferrari
Rep Power: 16 |
thank you very much!
best andrea |
June 7, 2013, 08:07 |
problem with makeAxialMesh
#155 |
shiv
Rep Power: 14 |
hi bernhard,
I am new to openfoam and i am facing few problems with using makeAxialMesh for a simple case of laminar flow thru a 2D axisymmetric pipe, can you please point out the probleam in my case setup since i am getting boundary layer even at the axis(as in the attached fig.). |
June 7, 2013, 12:22 |
#156 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
June 7, 2013, 14:49 |
#157 |
ali jafari
Rep Power: 14 |
June 7, 2013, 16:17 |
#158 |
shiv
Rep Power: 14 |
hi bernhard,
no i have not used collapseEdges, i simply gave these terminal commands blockMesh makeAxialMesh -axis center -wedge frontAndBack icoFoam >& log after running makeAxialMesh , a folder was formed from which i copied the polymesh dir. and replaced with the original. my original blockMeshDict convertToMeters 0.01; vertices ( (0 -1 0) (5 -1 0) (5 1 0) (0 1 0) (0 -1 2) (5 -1 2) (5 1 2) (0 1 2) ); blocks ( hex (0 1 2 3 4 5 6 7) (100 40 1) simpleGrading (1 1 1) ); edges ( ); boundary ( inlet { type patch; faces ( (0 4 7 3) ); } outlet { type patch; faces ( (2 6 5 1) ); } fixedWalls { type wall; faces ( (3 7 6 2) ); } center { type empty; faces ( (1 5 4 0) ); } frontAndBack { type empty; faces ( (0 3 2 1) (4 5 6 7) ); } ); mergePatchPairs ( ); and 0/u : internalField uniform (0 0 0); boundaryField { outlet { type zeroGradient; } inlet { type fixedValue; value uniform (0.05 0 0); } fixedWalls { type fixedValue; value uniform (0 0 0); } center { type symmetryPlane; } frontAndBack { type empty; } frontAndBack_pos { type wedge; } frontAndBack_neg { type wedge; } I am also not very sure about the parameters in rotationDict (attached). Will be grateful for ur help. |
June 8, 2013, 12:52 |
#159 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
You should have. That's why it is the last thing makeAxialMesh talks about it before it ends
June 17, 2013, 07:35 |
#160 |
shiv
Rep Power: 14 |
hi bernhard,
I am sorry , i didn't go thru prevoius threads. Thanks a lot for ur answer now its up and running, I also wanted to confirm something, thou collapseEdges 1e-06 175 command after makeaxialmesh worked for me on OF ver 2.1 but a friend of mine is getting troubles running the same command collapseEdges 1e-06 175 for same case on OF ver 2.2, whats the reason for that, its showing required 0 argument, 2 given |
Simplest way of converting a 2d Navier Stokes code to a 2d axisymmetric one | mseka | Main CFD Forum | 1 | September 18, 2017 15:53 |
Axisymmetric Boundary condition | Mohit Singh | SU2 | 3 | July 15, 2015 10:19 |
[mesh manipulation] Converting axisymmetric mesh into fully 3D mesh | tomloh | OpenFOAM Meshing & Mesh Conversion | 0 | April 29, 2012 21:31 |
Difference of final temperature between a plane and an axisymmetric geometry | douchka | FLUENT | 0 | July 7, 2011 09:38 |
URGENT ! Need help on Axisymmetric Flow ! | Suman Kumar | Main CFD Forum | 1 | November 20, 2001 15:51 |
