[mesh manipulation] Converting a 2Dmesh to axisymmetric |
August 8, 2012, 06:25 |
#121 |
Rep Power: 16 |
Hi again..
as reported before, I have the problem, that after MAM checkMesh or collapsEdges crashes with a floating Point Exception. I had this issue before but could solve it, by modifying the boundary of the mesh. Now I am facing this problem again, but cannot figure out, where the problem comes from. I'd be glad if someone could check the case. https://dl.dropbox.com/u/587565/gly8...wBackup.tar.gz Thanks in advance! Lindstroem |
August 20, 2012, 17:37 |
#122 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
August 21, 2012, 06:31 |
#123 |
Rep Power: 16 |
Hi Bernhard,
thanks for your help. Your posting made me starting from the scratch again. The problem was that I used the MAM-version for 1.4.1 to 1.7.x although my OF-version was 2.0.0. I had a wrong alias. I always thought it was a problem of my case! Thanks!! |
August 22, 2012, 03:13 |
plz help me dear foamers:
#124 |
vahid
Rep Power: 13 |
Hi foamers.
I am trying to convert the 2D mesh to 3D! my real geometry is (pic1) but i want to Use 2D for my solver(because in 3D very slow Running speed) ,and for this reason i made 2D(pic2). can I Change the type of frontAndBack and make 2D to 3D (pic3)??? my width 44mm. |
August 22, 2012, 05:36 |
#125 |
Rep Power: 16 |
Hello Vahid,
the width of your geometry does not matter (as you want to run a 2D simulation, if it does matter, it is not 2D anymore). Just make sure, it is only one cell big. Yes, frontAndBack should be of type empty. Greetings |
August 22, 2012, 08:39 |
Hi lindstroem
#126 |
vahid
Rep Power: 13 |
Hi lindstroem ,thanks for your answer.
your answer means should I use 3D geometry ???(because width of my real geometry is 44mm!!!) |
August 22, 2012, 09:45 |
#127 |
Rep Power: 16 |
Hi again,
two general things: - OpenFOAM uses for 2D simulations a mesh with only one cell in the "z-direction" (or which axis you choose to be perpendicular to the 2D-plane you simulate). So the mesh is basically 3D, but the boundaries (defined as empty) indicate for OF that it is a 2D case. (see U-126 in the User guide) - if you do a 2D simulation, your depth is "infinite". Otherwise it would be 3D if you want to account for the dependence on the depth. So you should make yourself clear what you want to simulate. I cannot recommend you what you should do, because it depends on what you want to solve for. |
August 22, 2012, 12:30 |
#128 |
vahid
Rep Power: 13 |
Hi Dear lindstroem .
thanks a lot for your Clear answer. |
September 25, 2012, 05:02 |
#129 |
ali jafari
Rep Power: 14 |
Hi
I start OF recently. I have O.F 1.5 dev . I download makeAxialmesh and try compile it according to threads but some errors appear (repatchPolyTopoChanger.H file error) please guide me for compiling this utility step by step. (specific paths ; specific commands ...) |
September 25, 2012, 05:17 |
#130 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Anyway: try getting this version (according to the README it should work with 1.5-dev but I can't check because I don't have such an old installation) with the following command svn checkout https://openfoam-extend.svn.sourcefo...MakeAxialMesh/ go to the makeAxialMesh-directory and do the usual wmake. But all that is described on http://openfoamwiki.net/index.php/Contrib_MakeAxialMesh anyway
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
September 27, 2012, 06:01 |
#131 | |
ali jafari
Rep Power: 14 |
I do your steps but when I run parafoam and click on apply . parafoam exiting and this error appears : --> FOAM FATAL IO ERROR: inconsistent patch and patchField types for patch type symmetryPlane and patchField type zeroGradient file: /home/ali/USER_RUN/tutorials/axialCavity/0/p::boundaryField::movingWall from line 34 to line 34. From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&) in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 164. FOAM exiting Segmentation fault (core dumped) ------------------------------------------------------------- I use checkMesh after blockMesh and that's OK , and I use checkMesh after makeAxialMesh but it show " Failed 4 mesh checks." how do I understand that I compile MakeAxialMesh correctly ? Last edited by ali jafari; September 27, 2012 at 06:41. |
September 28, 2012, 15:35 |
#132 |
Amin Shariat KHah
Rep Power: 15 |
Dear Ali
Did you tested testCase or another case? what is your OF version? |
September 29, 2012, 02:29 |
#133 |
ali jafari
Rep Power: 14 |
September 29, 2012, 03:58 |
#134 |
Amin Shariat KHah
Rep Power: 15 |
I think you should reinstall you OF 1.5 dev
and you couldn't run test case or your case? I can't understand. feel free to mail me: amin_144@yahoo.com |
September 29, 2012, 10:31 |
AnyOne have tested makeAxialMesh in OF 2.1.1 ?
#135 |
Amin Shariat KHah
Rep Power: 15 |
Hi Dear Foamers!
AnyOne have tested makeAxialMesh in OF 2.1.1 ? I have used it in 1.5dev before and it worked correctly as I said in my other posts in this thresd. but today I used it in OF 2.1.1 I compiled the version which is written for OF 2.0.0 and there isn't especial version of makeAxialMesh for OF 2.1.1 !! but when I ran "check mesh" (after collaspsing edges) it shows an error: ***Wedge patch frontAndBack_pos not planar. Point (0.005 0.06 0.00174478) is not in patch plane by 3.9962e-08 meter. Any change in code of this utility is needed for OF 2.1.1 ? TanX very much |
September 30, 2012, 06:13 |
#136 |
Rep Power: 14 |
Hi Amin,
I have had this problem before, you shouldn't need to change anything. See posts between Bernhard and myself in this threat, (post #106 onwards) Kind Regards, Tom |
November 13, 2012, 07:18 |
#137 |
Emil Baric
Rep Power: 14 |
Hello everybody, just one question is it possible to create a geometry that is symetric around a coordinate axis and not around one of its boundaries?
Thank you! |
November 20, 2012, 20:59 |
#138 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
What do you mean with "not around one of its boundaries"? Could you sketch it?
November 21, 2012, 02:13 |
#139 |
Emil Baric
Rep Power: 14 |
I managed to avoid it by creating wedge (5 degree slice) mesh in Gambit and then importing it into OpenFoam. I hope that procedure is ok. And what I ment is if the domain is ofset from x-axis for some measure and I want to revolve it around x-axis and not the boundary Thank you |
December 25, 2012, 14:39 |
rotationDict Confusing
#140 |
Rajesh Kumar
Rep Power: 17 |
What is the difference between new mode and old mode...Pls somebody explain it.
Simplest way of converting a 2d Navier Stokes code to a 2d axisymmetric one | mseka | Main CFD Forum | 1 | September 18, 2017 15:53 |
Axisymmetric Boundary condition | Mohit Singh | SU2 | 3 | July 15, 2015 10:19 |
[mesh manipulation] Converting axisymmetric mesh into fully 3D mesh | tomloh | OpenFOAM Meshing & Mesh Conversion | 0 | April 29, 2012 21:31 |
Difference of final temperature between a plane and an axisymmetric geometry | douchka | FLUENT | 0 | July 7, 2011 09:38 |
URGENT ! Need help on Axisymmetric Flow ! | Suman Kumar | Main CFD Forum | 1 | November 20, 2001 15:51 |
