Yesterday, 08:46 |
Hybrid Mesh Generation in Gmsh
Umut
Rep Power: 15 |
Dear all,
I’m trying to generate a 3D hybrid mesh on a fairly simple geometry using gmsh. I added all images, input and geo files below. The geometry is a box without a lid with air inside, meaning two concentric boxes. I want structured mesh on box solid and unstructured tetrahedral and pyramid cells in fluid domain (air inside the box). The mesh visibly generated as expected (please check images below). However gmsh gives warning about 36 ill-conditioned cells. When I export it as .msh and converted to Openfoam polyMesh folder, the mesh metrics are beyond terrible with all sorts of errors. I would highly appreciate if anyone can help (educate) me if and how I can generate hybrid mesh using gmsh (or in any opensource tool really). Cheers Input geometry files: https://drive.google.com/file/d/1P-S...ew?usp=sharing https://drive.google.com/file/d/1IVy...ew?usp=sharing Images: https://drive.google.com/file/d/1p0g...a2ppq5fKL/view https://drive.google.com/file/d/1a9Y...fMSeYD6JL/view Gmsh .geo file: If you download and try meshing it, don't forget to edit the Merge "Path/to/*.brep"; lines. Code:
//Hybrid mesh example SetFactory("OpenCASCADE"); // Merge geometries Merge "Path/to/outer.brep"; Merge " Path/to/inner.brep"; Coherence; // *** Structured Region *** // // Define Transfinite Curves (Ib) Transfinite Curve {103, 100, 97, 93, 68, 65, 72, 71, 32, 36, 40, 45, 29, 42, 37, 31, 83, 87, 101, 98, 57, 55, 41, 20, 16, 13, 38, 15} = 40 Using Progression 1; Transfinite Curve {88, 92, 104, 73, 62, 61, 46, 28, 24, 21, 43, 23, 76, 81, 96, 67, 53, 48, 35, 10, 6, 1, 30, 3, 91, 86, 80, 79, 51, 52, 63, 56, 8, 12, 19, 27, 2, 22, 14, 4} = 5 Using Progression 1; // Transfinite and Recombination for Surfaces For s In {1:74} Transfinite Surface{s}; Recombine Surface{s}; EndFor // Transfinite and Recombination for Volumes For v In {1:17} Transfinite Volume{v}; Recombine Volume{v}; EndFor // *** Un-Structured Region *** // //surface 75 and volume 18 should be unstructured (pyramid & tetrahedral cells) Mesh.OptimizeNetgen = 3; // or 2, 3 Mesh 3; |
gmsh, hybrid mesh, meshing, openfoam, preprocess |
flow over cylinder in openFoam | saeed jamshidi | OpenFOAM Pre-Processing | 3 | August 11, 2023 16:16 |
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" | GuiMagyar | OpenFOAM Meshing & Mesh Conversion | 3 | August 4, 2023 13:38 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[ICEM] Bad Quality Hybrid Mesh External Flow | tim13 | ANSYS Meshing & Geometry | 0 | March 8, 2020 03:22 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
