[snappyHexMesh] snappyhexmesh boundary layer number of layers limited by cell size ratio
Old   December 3, 2024, 09:37
Default snappyhexmesh boundary layer number of layers limited by cell size ratio
geth03 is on a distinguished road
hi all,
i was trying out shm and when i want to add layers i encounter a strange behaviour.
the number of layers i can add is limited by the ratio between cell size next to the layers and thickness of the last layer: CellSize / ThicknessFirstLayer < 100.
as long as this condition is ok i get the layers, if not the algo does not add one layer.
so i am not able to create layers more than 20 or so because from there on the ratio hits this value.
does anybody know anything about that?
geth03 is offline   Reply With Quote
Old   December 6, 2024, 10:39
Default Limited Layering Capability
Skill-Lync CFD
CFD_with_Skill-Lync is on a distinguished road
Generally, it is limited to 0.4 times the cell height closest to the boundary. You can make the calculations based on this metric. Making more than 10 layers is tricky with snappy.
CFD_with_Skill-Lync is offline   Reply With Quote
Averaging over iterations for steady-state simulation CFD student Fluent UDF and Scheme Programming 8 September 22, 2022 04:39
[snappyHexMesh] Boundary layers on complex curves with good tetQuality MikeWorth OpenFOAM Meshing & Mesh Conversion 0 August 4, 2020 08:03
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
SigFpe when running ANY application in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 23, 2015 15:53
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
