[snappyHexMesh] paraFoam displaying original blockMesh layout (URGENT)
Old   December 2, 2024, 09:49
Post paraFoam displaying original blockMesh layout (URGENT)
Hussain
hussainazam2002 is on a distinguished road
Might be a silly question but I am quite confused. After creating my blockMesh file, I have also configured and ran my snappyHexMesh. when I go to visualize this in paraFoam, I only see the original blockMesh cuboid until I change to the final time interval at which point the refined mesh appears. Is this correct? am i only supposed to be able to see the reformed mesh at the last interval?
hussainazam2002 is offline   Reply With Quote
Old   December 2, 2024, 09:59
Yann
Yann will become famous soon enoughYann will become famous soon enough
Yes, this is the default behavior of snappyHexMesh:
By default, each of snappyHexMesh’s phases, i.e castellation, snapping and layer addition will write a complete mesh in time folders. This behaviour can be suppressed by using the option
snappyHexMesh `-overwrite`
https://doc.openfoam.com/2306/tools/...snappyhexmesh/
Yann is offline   Reply With Quote
Old   December 2, 2024, 10:04
Post follow up on mesh
Hussain
Thanks for the help. Just out of curiosity, when I run my solver (rhoPimpleFoam), will the refined mesh be there from the first time interval?
also,
if my solver doesn't converge, should I still be able to visualize the results in paraview or is this only possible when it converges.
Old   December 2, 2024, 10:15
Yann
No it won't. You will have to manually move the final mesh into the constant directory. Or just use the -overwrite option when running snappy.
also,
You will be able to visualize data written to disk, if there is any. This is defined in the controlDict file.
Have a look to "Time and data input/output control" in the user guide.
[OpenFOAM.org] paraFoam command not working (installed openFoam from source + its Third-party) manle0312 OpenFOAM Installation 3 November 18, 2024 06:19
paraFoam crash(es) JayDeeUU OpenFOAM Post-Processing 0 December 13, 2020 22:23
[OpenFOAM.org] paraFoam Fatal Error upon run Gallienus OpenFOAM Installation 2 April 14, 2020 20:23
[OpenFOAM.com] paraFoam cannot open due to Qt issues - [Solved/Information] u2berggeist OpenFOAM Installation 2 July 2, 2018 18:03
ParaFoam, blockMesh etc in vnc SimonH. OpenFOAM 1 March 6, 2011 12:27
