[snappyHexMesh] How to generate baffles on open surfaces with snappyhexmesh |
November 28, 2024, 03:29 |
Rep Power: 2 |
Hi, I am trying to make a multiregion mesh with snapyhexmesh in openfoam, the case is air around and a rectangular pipe with a water flow inside.
The problem is that I visualize the mesh and the contour mesh generated by blockmesh cuts my study region, then I modify the blockmesh coordinates but then the mesh generated by snappyhexmesh disappears and I am left only with the contour mesh. in the log.snappyhexmesh I observe that it does not generate any baffles, but I have put the same conditions as in the shellandtubeheatexchanger tutorial. Do you know why this could happen? I am basing it on the shellandtubeheatexchanger CHT multiregion tutorial, it is openfoam12. createbaffles internalFacesOnly true; baffles { baffles1 { type faceZone; zoneName shell_to_solid; owner { name shell_to_solid; type mappedWall; neighbourRegion solid; neighbourPatch solid_to_shell; } neighbour { name solid_to_shell; type mappedWall; neighbourRegion shell; neighbourPatch shell_to_solid; } } baffles2 { type faceZone; zoneName air_to_solid; owner { name air_to_solid; type mappedWall; neighbourRegion solid; neighbourPatch solid_to_air; } neighbour { name solid_to_air; type mappedWall; neighbourRegion air; neighbourPatch air_to_solid; } } } snappyhexmeshdict #includeEtc "caseDicts/mesh/generation/snappyHexMeshDict.cfg" castellatedMesh on; snap on; addLayers off; geometry { shell { type triSurfaceMesh; file "shell.stl"; regions { inlet_s { name inlet_s; } outlet_s { name outlet_s; } } } air { type triSurfaceMesh; file "air.stl"; regions { inlet_a { name inlet_a; } outlet_a { name outlet_a; } down { name down; } top { name top; } laterales { name laterales; } } } solid { type triSurfaceMesh; file "solid.stl"; regions { external { name external; } } } shell_to_solid { type triSurfaceMesh; file "shell_to_solid.stl"; } air_to_solid { type triSurfaceMesh; file "air_to_solid.stl"; } }; castellatedMeshControls { features ( ); refinementSurfaces { shell { level (1 1); regions { inlet_s { level (1 1); patchInfo { type patch; } } outlet_s { level (1 1); patchInfo { type patch; } } } } air { level (1 1); regions { inlet_a { level (1 1); patchInfo { type patch; } } outlet_a { level (1 1); patchInfo { type patch; } } } } solid { level (1 1); regions { external { level (1 1); patchInfo { type wall; } } } } shell_to_solid { level (1 1); faceZone shell_to_solid; cellZone shell; mode inside; } air_to_solid { level (1 1); faceZone air_to_solid; cellZone air; mode inside; } } insidePoint (0 0.008 0.015); nCellsBetweenLevels 2; resolveFeatureAngle 15; } snapControls { implicitFeatureSnap true; } addLayersControls { layers { shell_to_solid { nSurfaceLayers 2; mergeFaces false; } air_to_solid { nSurfaceLayers 2; mergeFaces false; } } relativeSizes true; expansionRatio 1.2; finalLayerThickness 0.5; minThickness 1e-3; } mergeTolerance 1e-6; // ********************************************** // |
baffles, mesh generation problem, snappyhexmesh |
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 17:05 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 18:16 |
[snappyHexMesh] snappyhexmesh for open surfaces, like an annulus | vkannama | OpenFOAM Meshing & Mesh Conversion | 3 | December 1, 2017 03:57 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
OpenFOAM with IBM AIX | matthias | OpenFOAM Installation | 20 | March 25, 2008 03:36 |
