[mesh manipulation] cylinder cut plane to wedge mesh |
November 21, 2024, 08:02 |
Rep Power: 3 |
I have simulated a flow in a cylindrical mesh. Now, I intend to run another solver (let's say something like scalarTransporFoam) on the resulting velocity distribution. I only need to execute the second solver on a cut plane of the cylinder. This would be equivalent to map an axisymmetric geometry (with the wedge BCs) with the cut plane data, and use this as mesh for the second simulation (diagram attached for clarity). Apparently, it is not as simple as I had thought:
Do you happen to know an easier solution ? Thanks in advance |
map fields, map mesh, split mesh, toposet |
[snappyHexMesh] Is it a good mesh for a square cylinder ? | belier1988 | OpenFOAM Meshing & Mesh Conversion | 2 | September 10, 2020 12:59 |
Prescribed Translating Cylinder Mesh for Added Mass Problem (Transient FSI) | Lloyd Sullivan | CFX | 5 | August 7, 2018 09:11 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 04:19 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 10:03 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
