[snappyHexMesh] Multi Regions Meshing Errors
Old   November 13, 2024, 09:23
Default Multi Regions Meshing Errors
Suhan Umur Okuducu
suoCFD is on a distinguished road
Hello everyone,
I don't have much experience with OpenFOAM. I am working on a circuit board thermal analysis. I designed a geometry for it. I tried to model it using multiple tutorial cases, but the most suitable one was snappyMultiRegionHeater. I shared my case adapted from this, including the output of the scripts as well as an image of the problem geometry. To explain, the component and LED regions are the heat sources. The fluid inside the geometry is fluid2, and the fluid outside is fluid1. The commands used are:
blockMesh
surfaceFeatures
snappyHexMesh -overwrite
splitMeshRegions -cellZones -defaultRegionName fluid -overwrite
foamMultiRun
Since my knowledge of mesh is not very good, there might be some mistakes. There are some errors if you look .log files. However, the main problem is the lack of heat transfer between solid-solid interfaces. Heat transfer occurs between the fluid and solid interfaces, but not between the solid-solid interfaces. For example, heat transfer should happen from the component region to the pcb region, but the analysis does not give such results. Only the component region heats up and transfers heat to the fluid.
Please help me!
suoCFD is offline   Reply With Quote
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points Simurgh OpenFOAM Meshing & Mesh Conversion 4 August 25, 2023 08:58
[snappyHexMesh] Multi region meshing with SHM creates extra regions Dav3dum OpenFOAM Meshing & Mesh Conversion 0 August 8, 2016 09:54
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 11:49
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 03:34
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
