[blockMesh] blockMesh with refineMesh
Old   November 12, 2024, 11:36
Default blockMesh with refineMesh
ah_9 is on a distinguished road
Hi foamies,
I have a simple 2D cylinder geometry in which I need some refinement only in a particular lower area.
So I define a cellSet using topoSet and then refine the region recursively using refineMesh.
Can someone help me resolve this bad mesh on these particular regions?
This is my refineMeshDict
set ref;
coordinateSystem global;
globalCoeffs
tan1 (1 1 0);
tan2 (-1 1 0);
directions ( tan1 tan2 );
useHexTopology yes;
geometricCut no;
writeMesh no;
would snappyHexMesh give a better refinement? I did not try snappyHexMesh since I have a very simple 2D geometry
Any help would be great!
ah_9 is offline   Reply With Quote
Old   November 13, 2024, 12:07
Alczem is on a distinguished road
Hey!
The issue seems to be a lack of transitioning from the coarse cellsize to the fine cellsize.
Since you generate a fully hexaedral mesh before refineMesh, I would give snappy a try, since it will take care of the decreasing cellsize itself. You could for instance add a searchableBox in the geometry subdictionary, then proceed to refine by a level or two in the refinementRegions subdictionary.
I am not sure how good your edges will be kept though, so double check once you are done with snappy.
Otherwise, you will have to use refineMesh several times to create a smooth transition zone between the coarse region and the fine region (by creating several cellzones, each slightly larger than the previous one).
Alczem is offline   Reply With Quote
Old   November 14, 2024, 04:52
Originally Posted by Alczem View Post
Hey!
Thankyou for your reply! Okay, I will give snappy a try
Old   November 14, 2024, 12:12
Hey!
With using sHM my mesh seems fine now but my volume fields seems to just vanish. I am using setFields command after my snappyHexMesh -overwrite command. I don't know what seems to be the issue. Can you help me with this?
Old   November 15, 2024, 05:05
Hey!
It is probably due to some overwriting. My usual steps when meshing with snappyHexMesh are:
  • blockMesh
  • snappyHexMesh -overwrite
  • Copy the 0.orig folder to 0
  • setFields or whatever you need to initialize
  • Decompose and run the case
Based on your post, I would guess that the meshing process erases your 0 folder. Once you have run snappyHexMesh , make sure to copy your 0 folder once again, and run setFields.
Are you using cellzones with setFields? Maybe snappyHexMesh is not properly configured to create those, hence setFields won't work.
Can you share your case? I, or someone, will have a look when possible.
Old   November 15, 2024, 11:14
Hey!
  • blockMesh
Hey thanks for the reply again!
I can share my setFields and sHM files if that is ok.
And this is my procedure for reference
1. blockMesh
2. snappyHexMesh -overwrite
3. setFields
4. then run the solver.
I do not create the 0.orig, instead I have alpha.air.orig and alpha.particles.orig (which I then delete)
snappyHexMesh -
#includeEtc "caseDicts/mesh/generation/snappyHexMeshDict.cfg"
castellatedMesh on;
snap on;
addLayers on;
geometry
refinementBox
type searchableBox; // Define a box for the refinement region
min (-0.2 -0.2 0); // Minimum point of the box
max (0.2 -0.12 0.001); // Maximum point of the box
castellatedMeshControls
// Settings to control maximum cell count
maxLocalCells 5000000; // Max cells per processor
maxGlobalCells 10000000; // Max total cells
minRefinementCells 0; // Minimum cells required for refinement
nCellsBetweenLevels 2; // Smoothness between refinement levels
// Specify the refinement level for feature edges
resolveFeatureAngle 30; // Angle for resolving sharp edges
refinementSurfaces
// Define region to be refined
refinementRegions
refinementBox // Name of the box for the refinement region
mode inside; // Refine inside the box
levels ((1E15 2)); // Refinement level within the box
locationInMesh (0.0 0.0 0.0);
snapControls
// Snap settings (optional for refinement only)
nSmoothPatch 3; // Patch smoothing iterations
tolerance 2.0; // Tolerance for snapping
nSolveIter 30; // Number of solving iterations
nRelaxIter 5; // Number of relaxation iterations
//explicitFeatureSnap false;
//implicitFeatureSnap false;
addLayersControls
layers
// If boundary layers are needed, define them here
relativeSizes true;
expansionRatio 1.2;
finalLayerThickness 0.3;
minThickness 0.1;
nGrow 0;
meshQualityControls
// Standard mesh quality settings
maxNonOrtho 65;
maxBoundarySkewness 20;
maxInternalSkewness 4;
maxConcave 80;
minFlatness 0.5;
minVolRatio 0.01;
minTetQuality 1e-30;
minArea -1;
minTwist 0.05;
minDeterminant 0.001;
minFaceWeight 0.05;
minVolCollapseRatio 0.05;
// Advanced quality settings
relaxed
maxNonOrtho 75;
writeFlags
// Final settings for merging points
mergeTolerance 1E-6;
setFieldsDict -
defaultFieldValues
volScalarFieldValue alpha.air 1
volScalarFieldValue alpha.particles 0
regions
boxToCell
box (-0.2 -0.2 0) (0.2 -0.17112 0.001); //7.22% fill
fieldValues
volScalarFieldValue alpha.particles 0.6
volScalarFieldValue alpha.air 0.4
I can visualize my alpha.particles at time 0. but then they just disappear.
Old   November 15, 2024, 11:50
I don't see any issue. If you can see your field at t=0, but it does not exist for subsequent timesteps, it probably means that it is not used/written by the solver. What solver do you use? You can maybe make a different thread and share the whole case, I do not think anyone can tell what is wrong with just what you have shared unfortunately.
Old   November 20, 2024, 06:01
Hi again Alczem!
I found a problem while looking at checkMesh. Since I have a 2D geometry to start with frontAndBack faces with empty patch, sHM is also refining in the normal direction. Do you have any ideas how to fix this? I will also search for a fix now
[blockMesh] Problem with running blockMesh yoshiyagi OpenFOAM Meshing & Mesh Conversion 3 November 3, 2022 00:49
[mesh manipulation] BlockMesh cellSet refineMesh mattijs OpenFOAM Meshing & Mesh Conversion 41 April 7, 2020 10:32
[blockMesh] Multi-region Blockmesh - Refinemesh issues. Doug68 OpenFOAM Meshing & Mesh Conversion 3 February 18, 2016 21:09
[blockMesh] Multi-region Blockmesh - Refinemesh issues. Doug68 OpenFOAM Meshing & Mesh Conversion 0 February 17, 2016 04:39
[mesh manipulation] multiple calls to refineMesh parallel w/ dict failing Regis_ OpenFOAM Meshing & Mesh Conversion 2 June 4, 2015 14:44
