[Other] Build up of oscillating rotating motion
Old   November 7, 2024, 06:41
Default Build up of oscillating rotating motion
Pieter van Halem
Pieter van Halem is on a distinguished road
Hi all I currently have a working setup of a block oscillating in a fluid. I rotate the block with a dynamicMeshDict. I am intrested to get the forces that result from the oscillation on the block. However the oscillation starts directly. This results in unrealistic start-up effects. To counter this I want to gradually build up the forced motion. Does anybody know how to do that?
I rotate my entire mesh with the following dynamicMeshDict:
| \\ / O peration | Version: v1806 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object dynamicMeshDict;
dynamicFvMesh dynamicMotionSolverFvMesh;
motionSolver solidBody;
solidBodyMotionFunction oscillatingRotatingMotion;
oscillatingRotatingMotionCoeffs
origin (0 0 0);
amplitude (5.73 0 0);
omega 4.1888;
motionSolverLibs ( "libfvMotionSolvers.so" );
Pieter van Halem is offline   Reply With Quote
dynamicmeshdict, oscillatingrotatingmotion
Proper wall boundary condition for rotating AND oscillating cylinder in a flow de_Broglie OpenFOAM Pre-Processing 0 July 6, 2022 22:20
SU2 Parallel Build Install Issue jclegg SU2 4 October 20, 2020 05:28
using UDF for fluttering movement ( oscillating motion ) ??! bluAero Fluent UDF and Scheme Programming 7 June 20, 2013 06:37
Rotating domain motion in cfx post pankaj CFX 6 September 5, 2007 15:28
Motion of solids in rotating fluids Fredrik Kuivinen Main CFD Forum 2 July 6, 2000 13:40
