November 7, 2024, 02:31 |
Multi Region Meshing
Suhan Umur Okuducu
Rep Power: 2 |
Hi
I'm new to OpenFOAM. Before posting this thread, I reviewed almost all the tutorial cases in OpenFOAM, but I couldn't find one that suited my needs. Let me explain my problem as best as I can: imagine a closed pipe with a certain thickness. There will be air inside and outside of the pipe, and there could also be various solid objects within the pipe, positioned such that they do not touch the pipe walls. Additionally, materials need to be assigned to all solids and fluids. The problem involves both conduction and convection heat transfer. My question and request from you is this: what would be the correct way to mesh such a geometry? I couldn’t find an example that aligns with this type of geometry using snappyHexMesh. Best regards, and thank you for your time. |
November 7, 2024, 07:25 |
Yann
Rep Power: 29 |
For multiregion meshes created with snappyHexMesh, you can check the following tutorials:
Be careful to check the tutorial corresponding to your branch/version of OpenFOAM, as they do not handle multi region meshing the same way. Once you understand how meshing is handled in the tutorial, you should be able to adapt it to your own case. Have fun! Yann |
November 7, 2024, 10:29 |
#3 | |
Suhan Umur Okuducu
Rep Power: 2 |
Hello Yann, Thank you very much for your prompt response. I have reviewed these cases and many others like them. From what I understand, what you mean is to thoroughly understand the details of mesh generation with snappyHexMesh. However, I don't have the time in this project to delve into those details, which might be why the snappyHexMesh files in these tutorial cases haven't been helpful to me. Therefore, I need a snappyHexMesh setup that can mesh a geometry with an internal air region and additional solid geometries embedded within the innermost air region. Best regards |
November 7, 2024, 11:29 |
#4 | ||
Yann
Rep Power: 29 |
Hello Suhan,
Best regards, Yann |
November 7, 2024, 13:34 |
Suhan Umur Okuducu
Rep Power: 2 |
Thank you so much for your responses. I am going to apply what you mentioned when the time comes.
November 7, 2024, 17:42 |
Multi Region Constant Dictionaries Access | MMarczak | OpenFOAM Programming & Development | 1 | July 12, 2024 05:56 |
[snappyHexMesh] Multi region spliting doesn't result in desired boundaries | Hr_kules | OpenFOAM Meshing & Mesh Conversion | 1 | July 20, 2022 09:33 |
Problem simulating the temperature rise in a composite material (chtMultiRegionFoam) | Adam_K | OpenFOAM Running, Solving & CFD | 2 | March 27, 2019 07:51 |
[Other] mesh interface for multi region | Mohammad Jam | OpenFOAM Meshing & Mesh Conversion | 3 | December 5, 2016 08:23 |
Multi region meshing | noob@cfd | Siemens | 2 | March 26, 2012 13:32 |
