[Commercial meshers] Fluent Mesh into OpenFOAM
Old   October 24, 2024, 08:31
Default Fluent Mesh into OpenFOAM
berat
beratcagan is on a distinguished road
Hey,
I am trying to import my Fluent mesh into openFOAM, but it gives me the following error:
--> FOAM FATAL ERROR: (openfoam-2406)
: file "Reactor_periodic_1M_ASCII.mesh.h5" not found
From int main(int, char**)
in file fluent3DMeshToFoam.L at line 845.
FOAM exiting
I created the Mesh in Fluent Meshing but it only allows the exporting of *.msh.h5 or *.msh.gz files.
In all the tutorials I watched on this topic, people where using ICEM oder Workbench Meshing, where they are able to export the mesh as *.msh.
I dont know if this might be the reason.
Is there a way to export the Mesh from Fluent Meshing as *.msh only?
beratcagan is offline   Reply With Quote
Old   October 28, 2024, 10:18
Hrvoje Jasak
gunzip the gz file and try with that
Hrvoje Jasak
Old   October 28, 2024, 12:46
Krapf is on a distinguished road
Go in Fluent Meshing to File > Preferences> General and set Default Format for I/O to Legacy. Then you should be able to export your mesh as *.msh.
Krapf is offline   Reply With Quote
fluent, meshing, openfoam
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
[Commercial meshers] Fluent Mesh (XP32) to OpenFoam archymedes OpenFOAM Meshing & Mesh Conversion 1 April 1, 2010 06:26
