[Commercial meshers] from Ansys: fluent3MeshToFoam Error
Old   October 18, 2024, 05:12
Default from Ansys: fluent3MeshToFoam Error
fanta is on a distinguished road
Hi, i receive a Error from a Mesh I created with Ansys Workbench 2023 R2:
--> FOAM FATAL IO ERROR: (openfoam-2406)
Syntax error in expression at position:5
0.24//1700
^^^^ near here
My settings didn't change and the mesh ist not that big (~3GB). I never had that error. I use Ansys with Windows and dos2unix to convert to Linux.
Anyone knowing what to do?
fanta is offline   Reply With Quote
Old   October 18, 2024, 05:54
Krapf is on a distinguished road
Have you tried it without dos2unix? I use ICEM under Windows to create msh meshes and have always been able to convert them to the OpenFOAM format without using dos2unix first.
Krapf is offline   Reply With Quote
Old   October 18, 2024, 06:53
Regarding the error it doesn't make a difference, the error is still there.
Old   November 23, 2024, 02:41
Now this is still there, but i isolated the issue to the OpenFOAM environment:
-I meshed a simple pipe (14 mm pipe diameter, 500mm length) with an inlet, outlet and a wall with ansys CFD PrepPost, as usual.
Since i have two machines to run the OpenFOAM calculations, i tested with the other one and i have no problems with fluent3dMeshToFoam. Only on one machine, but there with every mesh. So i did a complete reinstall of OpenFOAM but that did not help, the issue still exists. I coinsider to reinstall Ubuntu.....
[swak4Foam] swak4foam openfoam 7 installation problem Andrea23 OpenFOAM Community Contributions 1 February 17, 2020 19:11
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
long error when using make-install SU2_AD. tomp1993 SU2 Installation 3 March 17, 2018 07:25
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
