[blockMesh] How is the blockMesh grading in the online script calculated ?
Old   September 22, 2024, 13:11
Default How is the blockMesh grading in the online script calculated ?
ishan
ishan_ae is on a distinguished road
I am automating some of my meshing needs using Python and I am trying to understand how the online blockMesh grading calculator works: https://openfoamwiki.net/index.php/S...ng_calculation.
I have the following known quantities:
  1. The first cell height \Delta y_{1}
  1. The last cell height \Delta y_{end}
  1. The height of the boundary layer \delta_{99}
I want to find the following unknown quantities:
  1. The cell-to-cell growth ratio r
  1. The number of cells N
Using the standard formulas for geometric progression, I derived the following formulas for r and N:
  1. r = \frac{\Delta y_1 - \delta_{99} }{\Delta y_{end} - \delta_{99}}
  1. N = \frac{log(\Delta y_{end}/\Delta y_1)}{log(r)} + 1
Using these formulas, my calculations don't match with the blockMesh grading script. What I have found is that the value of r from the online tool is much more accurate than my calculations. Is it because the script may be using bisection method for root finding ?
I am wondering where I am going wrong because these formulas are a result of simple re-arrangement of standard formulas.
ishan_ae is offline   Reply With Quote
blockmesh simplegrading
[blockMesh] Problem with running blockMesh yoshiyagi OpenFOAM Meshing & Mesh Conversion 3 November 3, 2022 00:49
dsmcFoam setup hherbol OpenFOAM Pre-Processing 1 November 19, 2021 02:52
[blockMesh] BlockMesh grading calculator hartinger OpenFOAM Meshing & Mesh Conversion 29 November 28, 2020 12:15
OpenFOAM advanced training - Online. July-August, 2020 (https://bit.ly/2CcYQ11) joegi.geo OpenFOAM Announcements from Other Sources 0 June 16, 2020 05:25
CFD Online Celebrates 20 Years Online jola Site News & Announcements 22 January 31, 2015 01:30
