[Other] Is there any working opensource meshing tool OF
Old   August 16, 2024, 03:38
Default Is there any working opensource meshing tool OF
Fun Times
happyHexMesh is on a distinguished road
Is there any working opensource meshing tool? I have complex geometry in stl format and multiregion case. Snappyhexmesh performs incredibly bad. It steals 15 gt ram for 1 million cell case, cant add layering in corners (ive tried in 100 different settings, increased blockmesh quality etc) and overall its performance is just like rolling the dice. Meshing process for same geometry takes like 1 minute using gmsh but 20 minutes using snappy. However, gmshtofoam dont work. All conversion tools from other free meshers are outdated and dont work with newest versions of OF. plz recommed a good work flow for creating multi region mesh from stl files )
btw reducing amount of cores in multirun do not help with the memory robbery and distributedTriSurfaceMesh instead of triSurfaceMesh in snappy configuration using hierarchial method in decomposeParDict only causes errors and snappy wont run at all
happyHexMesh is offline   Reply With Quote
Old   August 28, 2024, 06:52
rocketLauncher is on a distinguished road
There is Salome but it's mostly for Tetra
I would propose you try snappyHexMesh with BaramCFD. It's got a great UI and much easier to control once you have visualisation.
Otherwise you can try cfMesh or Gmsh
rocketLauncher is offline   Reply With Quote
Opensource Shrink Wrapping Tool Attesz Mesh Generation & Pre-Processing 1 March 18, 2017 10:02
[ANSYS Meshing] Meshing a flat plate with cooling holes with a plenum using Centaur as a Meshing tool TheStudent ANSYS Meshing & Geometry 0 March 13, 2017 10:58
Lid Tool and Meshing FloEFD zdunol FloEFD, FloWorks & FloTHERM 3 August 22, 2016 12:08
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 11:49
Dominant Meshing Tool Selina Tracy Main CFD Forum 6 April 1, 2001 09:34
