August 5, 2024, 09:34 |
About BlockMesh
Cesar Alessio de Britto
Hello, I'm trying to create a block of a complicated geometry that has to have more than 8 vertices that the blockmesh understands as the hexagonal block. How do I do this?
Thank you! |
August 6, 2024, 09:23 |
Gerhard Holzinger
Rep Power: 28 |
If you can assemble your geometry using hexahedral blocks, then blockmesh is the tool for the job. Note, that blocks may also feature curved edges.
If your geometry is too complicated to be built-up from blocks, then you're better off using a different tool. |
Problem with blockMesh | yoshiyagi | OpenFOAM Pre-Processing | 2 | November 7, 2022 06:49 |
[blockMesh] Problem with running blockMesh | yoshiyagi | OpenFOAM Meshing & Mesh Conversion | 3 | November 3, 2022 00:49 |
[blockMesh] OpenFOAM blockMesh bus error | BRH | OpenFOAM Meshing & Mesh Conversion | 0 | April 12, 2021 12:02 |
[blockMesh] set of xyz data in blockMesh | psk | OpenFOAM Meshing & Mesh Conversion | 12 | August 27, 2013 09:37 |
Blockmesh cavity error message | tonitoney | OpenFOAM Installation | 2 | March 17, 2008 12:59 |
