[snappyHexMesh] Mesh a seabed created from bathymetry file |
Rep Power: 0 ![]() |
Hello Foamers,
I created an STL file from bathymetric data. I would then like to use this seabed as the bottom of my domain to simulate waves. The problem is that when I look at the alpha.water as indicated by the images attached to this message, the water goes below the seabed. How can I ensure that after blockMesh and snappyHexMesh, the new patch 'ground' is associated with the seabed geometry? Best Regards, |
mesh, seabed, snappy hex mesh, wave |
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 16:05 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
