[snappyHexMesh] cellSet (or cellZone) refinement by snappyHexMesh |
July 8, 2024, 11:44 |
Jacob Child
Rep Power: 2 |
Hello all!
Second post here, feel free to correct any forum/thread things I don't do correctly. Problem: I have an external mesh. I have created a cellSet using a topoSetDict and topoSet, and I want to refine it using snappyHexMesh (I thought this was done in the snap step, but is it castellation? I tried both). However, snappy doesn't seem to see it or refine it. Information: I called the cellSet GeneralRefine and also converted it to a cellZone as well. Under refinementRegions I put: Code:
GeneralRefine { levels ((2 2)); mode inside; } Code:
GeneralRefine { levels (2 2); cellZones GeneralRefine; cellZoneInside inside; } More in depth: The mesh is generated outside of snappy. I want to do some local refinement based off of a field function, so I created a cellSet and then originally ran refineMesh on that cellSet. This worked, but led to some unintented consequences such as large jumps between sizes. In snappy you can specify the number of cells between levels, so I was hopeful of creating the cellSet and then using snappy to refine it by just running the snap stage. Just in case I also ran the castellation stage, but it also didn't do anything. Could I create the cellSet in snappy based off of a field? |
cellsets, cellzones, refinemesh, snappyhexmesh |
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 01:37 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
