[snappyHexMesh] Hex-Dominant Parametric Meshing on SimScale
Old   June 30, 2024, 01:35
Exclamation Hex-Dominant Parametric Meshing on SimScale
Novi
nuofei is on a distinguished road
I'm using SimScale to run an analysis of a turbine under steady-state external flow simulation. I want to use their hex-dominant parametric meshing which implements SnappyHexMesh by OpenFoam.
In standard meshing, I needed to create the external flow domain and delete the bodies of my geometry. It will create hollow parts in the flow domain representing the geometry. Does this apply to hex-dominant parametric mesh as well? Or do I just leave my geometry as it is?
Below shows the comparisons:
This is quite URGENT! Please help me.
nuofei is offline   Reply With Quote
hex dominant method, hex meshing, meshing 3d, rotating bodies
[OpenFOAM] Error !! No. of points and fields don't match mkjmalik ParaView 4 November 2, 2019 11:37
[blockMesh] Openfoam: Meshing, where do my defaultFaces come from syntex OpenFOAM Meshing & Mesh Conversion 19 December 10, 2018 08:21
[ICEM] Split wall in Hex meshing Gert-Jan ANSYS Meshing & Geometry 1 March 21, 2018 11:40
[blockMesh] blockMesh with parametric mesh. Unusual and unseen problem 13msmemusman OpenFOAM Meshing & Mesh Conversion 1 June 13, 2016 03:25
strange problem with data seav OpenFOAM Running, Solving & CFD 0 April 11, 2014 06:01
