Sebastian Thaler
Rep Power: 2 ![]() |
Hey,
i need some help. I am currently working with OF11. My geometry is part of a bipolar plate inside a fuel cell. The case is a CHT setup with 3 regions (coolant,sheets and gases: from outer to inner). My goal is now, to couple the coolant patches on top with those on the bottom. I tried cyclic but sHM apparently cannot work on coupled patches. What are alternatives to implement the coupling? Thanks in advance |
Sebastian Thaler
I did some more testing.
When I try to couple the patches after sHM with “createPatch” I get an error that I do not understand. Unfortunately, I don’t have this error message now. Then I tried the “nonConformalCyclic”. When I use “createNonConformalCouples” and then check the boundary file, the original patches are still there, together with a nonConformalCyclic and a nonConformalError Version. The latter two can defined in the 0/region/fields-files with the include-constraint trick but the original two still need some boundary-types. The simulation is running but I don’t know whether the coupling actual happened or not. Lastly, I tried the mapped constraint type. I got it working with the mappedInternal-Version, but I don’t know if that’s good. |
steadyUniversalMRFFoam Tutorial fails in MixingPlane | HenrikJohansson | OpenFOAM Bugs | 0 | February 14, 2019 04:48 |
[Other] dynamicTopoFVMesh and pointDisplacement | RandomUser | OpenFOAM Meshing & Mesh Conversion | 6 | April 26, 2018 07:30 |
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 13:48 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Problem with cyclic boundaries in Openfoam 1.5 | fs82 | OpenFOAM | 36 | January 7, 2015 00:31 |
