[CGNS] Import .cgns mesh file into an open-source aerodynamic solver(DUST)
Old   June 26, 2024, 05:23
Default Import .cgns mesh file into an open-source aerodynamic solver(DUST)
Boqiao HUANG
TDK9958 is on a distinguished road
I am trying to import .cgns mesh file of a cylinder into DUST, an open-source aerodynamic solver developed by Polytechnic of Milan in FORTRAN. I know that this solver is not widely used, but any experience of using other open-source solvers, such as SU2, could help!
I created my cylinder in many different mesher, such as Fluent Meshing/Pointwise/ICEM/GMSH. Each time after finishing meshing the cylinder, I saved it as .cgns file. Above is the way I get my .cgns file. But when I imported the file into DUST, the error happened. When I imported the mesh created by ICEM, the error was unsupported CGNS element type: 17 NONE; in the case of GMSH, the error was neighbouring elements with opposed normal orientation,this is not allowed; in the case of Pointwise, the error was again unsupported CGNS element type: 10 NONE, the same error as in the case of Fluent Meshing.
Do you know how to identify where the problem is and how to correct it? Thanks a lot.
TDK9958 is offline   Reply With Quote
Old   June 26, 2024, 05:50
Boqiao HUANG
I think I wrongly created the cgns files because when I opened them in Paraview, there are no cell or point arrays. Is it normal?
Old   November 8, 2024, 08:13
Callum
walcal is on a distinguished road
Hi, did you manage to solve this issue? I'm running into the exact same problem
walcal is offline   Reply With Quote
.cgns
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 5 January 17, 2023 17:05
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 11:03
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
