June 25, 2024, 12:12 |
blockMesh not working
Dipta Bhadra
~/openfoam11/tutorials/fluid/cavity$ blockMesh
--> FOAM FATAL ERROR : Could not find mandatory etc entry (mode=ugo) 'controlDict' this is my first experience on OpenFOAM.When I try to use blockMesh according to the tutorial, it is showing the error. |
July 18, 2024, 03:53 |
Rep Power: 2 |
Could you share a picture of your working directory?
controlDict is a file that dictates the parameters of the simulation (nb of iterations, start time etc)and it's found in the system folder. Perhaps when you copied the tutorial directory you didn't capture everything. |
[OpenFOAM.com] OpenFOAM isn't working anymore: "blockMesh: error while loading shared libraries" | Leech | OpenFOAM Installation | 27 | July 29, 2024 05:45 |
[blockMesh] blockMesh coordinate system | pardoa | OpenFOAM Meshing & Mesh Conversion | 5 | October 23, 2023 13:29 |
[Other] BlockMesh Permissions Workaround Not Working - File Locations | LaserCooling | OpenFOAM Installation | 1 | August 22, 2023 05:01 |
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 | bjdarrer | OpenFOAM Installation | 7 | August 25, 2020 19:15 |
what "If" condition means in rebound | brbbhatti | OpenFOAM Programming & Development | 0 | August 12, 2014 09:18 |
