[snappyHexMesh] Interrupted Boundary Layer
Old   June 19, 2024, 12:00
Default Interrupted Boundary Layer
rocketLauncher is on a distinguished road
Hi all,
After a lot of experimenting, I am managing to get a rather good mesh with snappy. I am having some trouble with the boundary layer at certain points however. The BL will be constructed well and the start degrading before it's completely interrupted.
I attach some pictures to demonstrate the issue and my snappyHexMeshDict. Thank you in advance.
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap            true;
addLayers       true;
geometry
    inlet1.stl
	name	inlet1;
	type	triSurfaceMesh;
    inlet2.stl
	name	inlet2;
    outlet.stl
	name	outlet;
    symmetry_plane.stl
	name	symmetry_plane;
    walls.stl
	name	walls;
// Settings for the castellatedMesh generation.
castellatedMeshControls
    // Refinement parameters
    maxLocalCells 500000;
    maxGlobalCells 6000000;
    minRefinementCells 10;
    maxLoadUnbalance 0.10;
    nCellsBetweenLevels 3;
    // Explicit feature edge refinement
    features
            file    "inlet1.eMesh";
            level   4;
            file    "inlet2.eMesh";
            level   4;
            file    "outlet.eMesh";
            level   4;
            file    "symmetry_plane.eMesh";
            level   4;
            file    "walls.eMesh";
            level   4;
    // Surface based refinement
     refinementSurfaces
	inlet1
		level	(4 4);
		patchInfo
			type	patch;
	inlet2
		level	(4 4);
		patchInfo
			type	patch;
	outlet
		level	(4 4);
		patchInfo
			type	patch;
	symmetry_plane
		level	(4 4);
		patchInfo
			type	symmetry;
			inGroups (symmetry);
	walls
		level	(5 5);
		patchInfo
			type	wall;
			inGroups (walls);
    // Resolve sharp angles
    resolveFeatureAngle 30;
    //planarAngle 30;
    // Region-wise refinement
    refinementRegions
        // Define any refinement regions here if needed
    // Mesh selection
    locationInMesh (0.01937 0.01 0.023);
    allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
    nSmoothPatch 3;
    tolerance 4.0;
    nSolveIter 0;
    nRelaxIter 5;
    // Feature snapping
    nFeatureSnapIter 10;
    implicitFeatureSnap false;
    explicitFeatureSnap true;
    multiRegionFeatureSnap false;
// Settings for the layer addition.
addLayersControls
    relativeSizes true;
    layers
        walls
            nSurfaceLayers 10;
    expansionRatio 1.1;
    finalLayerThickness 0.1;
    minThickness 0.01;
    nGrow 0;
    featureAngle 5;
    slipFeatureAngle 5;
    nRelaxIter 3;
    nSmoothSurfaceNormals 1;
    nSmoothNormals 3;
    nSmoothThickness 10;
    maxFaceThicknessRatio 0.5;
    maxThicknessToMedialRatio 0.3;
    minMedialAxisAngle 90;
    nBufferCellsNoExtrude 0;
    nLayerIter 50;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
    maxNonOrtho 65;
    maxBoundarySkewness 20;
    maxInternalSkewness 4;
    maxConcave 80;
    minVol 1e-13;
    minTetQuality 1e-30;
    minArea -1;
    minTwist 0.02;
    minDeterminant 0.001;
    minFaceWeight 0.02;
    minVolRatio 0.01;
    minTriangleTwist -1;
    // Advanced
    nSmoothScale 4;
    errorReduction 0.75;
// Advanced
// Flags for optional output
debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
mergeTolerance 1e-6;
rocketLauncher is offline   Reply With Quote
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
Any formula for approximating the boundary layer thickness around a cylinder? bestniaz Main CFD Forum 0 October 24, 2015 03:00
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
errors Fahad Main CFD Forum 0 March 23, 2004 14:20
